| torque spec for valve cover https://slantsix.org/forum/viewtopic.php?t=55412 |
| Author: | martin53 [ Wed May 21, 2014 10:42 am ] |
| Post subject: | torque spec for valve cover |
How much do I torque the valve cover rubber gasket |
| Author: | Reed [ Wed May 21, 2014 11:32 am ] |
Snug! |
| Author: | Old6rodder [ Wed May 21, 2014 1:02 pm ] |
Snug ..... just. As noted. On the rubber gaskets, I like to replace the "normal" washers with the triangular intake/exhaust manifolds ones, to spread the load out a bit better. I get less "bowling" at the holes (due to the thicker & softer gasket) that way. |
| Author: | wjajr [ Wed May 21, 2014 1:16 pm ] |
I use a nut driver to tighten the bolts to a firm snug. |
