new rearend speedo question
https://slantsix.org/forum/viewtopic.php?t=55443
Page 1 of 1
Author:  '67 Dart 270 [ Mon May 26, 2014 5:31 pm ]
Post subject:  new rearend speedo question
I swapped out my 7.25 for an 8.75 with 3.55 gears. I assume my original gears were 3.23 ish, I don't know. My car had 165 80R/13's when I bought it, and I put 185 70R/14's on it (a tad larger diameter) which should have made the speedo read about 3.4% too fast. Now, with the 3.55 gears, I'm not sure where I am with the speedo.
Does anybody know what gear color goes in the A-904 with 3.55 gears?
thanks,
B
Author:  DusterIdiot [ Mon May 26, 2014 5:36 pm ]
Post subject:  Yipes!!!
3.55 rear gears
185/70/14's
Is a 38.47 tooth gear, so you get to decide if a 38 or a 39 will work best and correct the few mph error in either direction...
I would have gone 205/70/14 with that ratio at a minimum, 195's would a be little better...3200 rpm + at 60 mph is going to get old quick without an OD tranny.
Author:  '67 Dart 270 [ Mon May 26, 2014 6:51 pm ]
Post subject:  Thanks
Maybe I should wait until I get my final tire/rim choice. I'm eventually going to 215 60R/15's. At least I know whom to ask!
I'm with you on the OD tranny setup. I threw this rear end in because I got such a good deal on it (good thing because my 7.25 blew out). I think somebody told me I could change the valve body in my A-904 and get an overdrive, does that sound right?
I wonder what my speedo is really reading, say at 60 mph how fast am I really going. I hooked up a tach I had lying around and it looks like I'm running about 2800 rpm at "60" whatever "60" is.....
Brian
Author:  '67 Dart 270 [ Mon May 26, 2014 6:52 pm ]
Post subject:  8.75
At least swapping gear sets is easy now....not that I want to do that....
Author:  '67 Dart 270 [ Mon May 26, 2014 7:19 pm ]
Post subject:  swap..
This was literally emergency surgery. I work about 50 miles from my house and I was on the way home. As I drove the rear end got louder and louder...I just happened to have a set of earplugs handy and by the time I got home I had them in...axle bearings fried. But hey it lasted 47 years.
Author:  DusterIdiot [ Tue May 27, 2014 5:32 am ]
Post subject:  It's about...
2800 rpm with that gear and tire combo is about 52 mph.
You need a new tranny or a gear vendor unit to get that extra gear.
Author:  wjajr [ Tue May 27, 2014 5:50 am ]
No.
Overdrive transmission would be a whole different rig with four gears; three being the same stock ratios, and a fourth gear with a ratio around 0.8 or so engine revolutions to 1 turn of drive shaft.
Lock-up uses a different valve body and torque converter, and is not an over drive.
For your viewing pleasure:
See here for different transmissions used over the years.
Spedo gear chart here.
Author:  '67 Dart 270 [ Tue May 27, 2014 12:00 pm ]
Post subject:  thanks for the info...
I really like the low-end power increase with the 3.55's, I think an OD tranny is the way to go...
I'll check out the options...
oooh, my mind wanders over to the manual conversion realm...
brian
Author:  '67 Dart 270 [ Tue May 27, 2014 12:18 pm ]
Post subject:  Looks like it's not an easy thing...
I thought the later automatics were an easier swap than I'm reading about...
That gear set swap is looking better and better...
Author:  Reed [ Tue May 27, 2014 12:47 pm ]
There is no gearset swap that will turn a three speed 904 into a three speed 904 with overdirve. The only ways to add overdrive to a 904 is (a) a Gearvendors unit, or (b) a Laycock de Normanville overdrive from a vehicle like a Volvo.
Pre late 70s 904s are three speeds with no lockup. Late 70s to 1981 904s are three speeds with lockup. 1981 and pater 904s are three speeds with lockup AND a wide-ratio three-speed gear set. The wide ratio gearset has a lower ratio first and second gear (higher numerically) to help get heavy vehyicles moving with the higher (lower numerically) rear gear ratio axles used in those years.
If you are thinking of putting a wide ratio gearset into your 904 to lower your highway RPMs, don't. The wide-ratio gearset has the same third gear ratio as the "narrow" ratio gearset. First and second gears will actually make the engine rev higher but will launch the car easier. If you have a 3.2 or higher (lower numerically) rear axle gear ratio, the wide ratio gearset is beneficial. But with 3.55 rear gears it really isn't worth the effort to swap the gearset in the trans.
A lockup transmission wouldn't hurt anything, but it only lowers highway engine RPMs by at most 5%. Not worth it in my book unless you are replacing or rebuilding the transmission anyway.
I say, adjust your bands and add a shift kit, then drive it.
Author:  '67 Dart 270 [ Tue May 27, 2014 1:04 pm ]
Post subject:  gear swaps...
It drives perfectly, shifts well, what might I gain from adjusting the bands, etc.?
I was just investigating swapping the rear end gear set; does anyone know if someone sells a 3.23 or 2.76 ring and pinion for a 741 case? I can only find 3.55 and 3.73's out there...
brian
Author:  '67 Dart 270 [ Tue May 27, 2014 1:08 pm ]
Post subject:  what about these?
Are 2.94's a decent match to the slant?
I found a NOS set of 2.94's
brian
Author:  Reed [ Tue May 27, 2014 1:24 pm ]
Post subject:  Re: gear swaps...
Peace of mind that they are adjusted properly since the bands are wear items and adjusting them is actually part of routine maintenance.
brian
Ah. I misunderstood. I thought you meant swapping the gearset in the 904, not the ear axle. My favorite rear axle ratio with a three speed trans is 2.9ish or 3.2ish for a medium to light weight passenger car, and 3.5 for a heavy truck or van. Overdrive vehicles should have no higher (numerically lower) rear axle gear ratio than 3.5. 3.9s are really better behind an OD trans (auto or stick).
Author:  '67 Dart 270 [ Tue May 27, 2014 2:24 pm ]
Post subject:  spline count
What's the spline count on a 741 case pinion, is it 29 spline? I see some places list 29 spline, some say 30 spline others say 10 spline (coarse) did they make all those types?
b
Author:  '67 Dart 270 [ Tue May 27, 2014 5:26 pm ]
I see they made 29 spline and 10 spline for the 7260 yoke.
b
