It is currently Mon Jun 15, 2026 6:34 am
 Post subject: Dads truck
PostPosted: Fri May 30, 2014 3:28 am
You sent me an e-mail the other day wanting some wiper parts from my parts truck. I will give them to you no problem assuming this does turn into just a parts truck.
I found a cracked frame last weekend and so that curtailed my thoughts of putting a harness in it ( which I did get already ) and putting it back on the road, just getting more and more not worth messing with other than to get it running.
Anyway your e-mail was deleted by mistake, if you would like to e-mail me again than I will reply to that.
jhason2@yahoo.com
PostPosted: Fri May 30, 2014 2:28 pm
Sent an email to you, can you not use the message system here on .org?
PostPosted: Fri May 30, 2014 3:57 pm
No I cannot, received your e-mail and will reply.
PostPosted: Fri May 30, 2014 4:41 pm
If you are parting that truck out, I'd be interested in the instrument cluster. my email is mopar4me at shentel dot net. Thanks!
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Fri May 30, 2014 5:06 pm
Not certain what I will do with the truck as of yet, instrument cluster that I received with the truck is prob. not original to the truck. Its is the same as my 1986 instrument cluster. Not sure if 83s are the same?
