It is currently Mon Mar 03, 2025 11:02 am
 Post subject: Mounting a degree wheel
PostPosted: Sun Jun 15, 2014 11:35 am
Id like to know how you guys are mounting your degree wheel, is there a special fixture that I can buy?
My biggest issue is getting the degree wheel tight since the end of the crank is recessed into the pulley about 2-3 inches.
What are you guys using? Id like something that has a quick action release so I can turn the wheel if need be without an issue.
I have seen on You-Tube these fast releases but not for Slant engines.
Thanks
PostPosted: Sun Jun 15, 2014 12:10 pm
http://slantsix.org/forum/viewtopic.php ... pener+bolt
Users browsing this forum: No registered users and 22 guests
