carburator installation
https://slantsix.org/forum/viewtopic.php?t=55601
Author:  josekh7 [ Sat Jun 14, 2014 10:01 am ]
Post subject:  carburator installation
Hey guys fairly easy question is there a recomended torque specs to bolt down a carb i have a 2280..Reason being every time i uninstall the carb and i see the mounting gasket i can see the vacuum crevices stamped into the gasket..so i might be over torquing?
Author:  DadTruck [ Sun Jun 15, 2014 4:51 am ]
It is possible to over torque , but seeing the imprint of the carb base details is normal. I run the stud nuts down firmly with hand tools, recheck after a few heat cycles. The better carb base gaskets have compression limiters in the mounting holes, on those you can't over squeeze the gaskets.
