It is currently Mon Mar 03, 2025 3:09 pm
 Post subject: carburator installation
PostPosted: Sat Jun 14, 2014 10:01 am
Hey guys fairly easy question is there a recomended torque specs to bolt down a carb i have a 2280..Reason being every time i uninstall the carb and i see the mounting gasket i can see the vacuum crevices stamped into the gasket..so i might be over torquing?
1970 Dart Swinger Matching Numbers..
PostPosted: Sun Jun 15, 2014 4:51 am
It is possible to over torque , but seeing the imprint of the carb base details is normal. I run the stud nuts down firmly with hand tools, recheck after a few heat cycles. The better carb base gaskets have compression limiters in the mounting holes, on those you can't over squeeze the gaskets.
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 28 guests
