| Upgrades https://slantsix.org/forum/viewtopic.php?t=55624 |
| Author: | ILMopars [ Mon Jun 16, 2014 6:35 pm ] |
| Post subject: | Upgrades |
I've reached the point where the car NEEDS to come apart because she's just too plain tired. The rear end needs a rebuild then I want to MAYBE improve the brakes and I was wondering if the 10" drums came on a 7 1/4" or if an 8 3/4" is required. My plan was to put Kelsey Hayes disc brakes up front, but keep the system manual. Any input would be greatly appreciated. |
| Author: | wjajr [ Tue Jun 17, 2014 6:14 am ] |
[quote]My plan was to put Kelsey Hayes disc brakes up front[/quote] That will work with your existing small ball joint upper control arm, but you will need to change steering knuckle (not so easy to locate these parts, these were optional A Body only, years 1967-73) and lower ball joint for a KH disk brake unit, and convert to small bolt 14†rims. Disks for A Body KH are hard to source and expensive. See Rock auto for rebuild kits and rebuilt calipers, they have best prices and availability. A cheaper and part friendly availability method would be to use single piston stile upper big ball joint later A body 1974 & newer or newer Aspen platform cousins conversion, 4.5†bolt pattern, or aftermarket disk brake conversion kit that utilizes later more common (read inexpensive) parts and your existing steering knuckle and a 14 inch wheel. Can't help with 10" rear drum Q. |
| Author: | DusterIdiot [ Tue Jun 17, 2014 6:39 am ] |
| Post subject: | It's... |
Quote: single piston style upper big ball joint later A body 1974 & newer
Single Piston disc brakes were model years 1973-1976 in A-bodies and 1976-up in the Aspen/Diplomat/etc... bodies...Mopar made them mandatory in cars made after Jan.1976.
| Author: | ILMopars [ Thu Jun 19, 2014 6:53 pm ] |
Hmm, OK thanks for the input on this. I would feel better with four-piston calipers. I saw the K-H Calipers on Rock Auto and they are about $100 per side. That does not concern me, what is an issue is locating a set of spindles. I will continue this in the brakes forum. I was curious as to what can be done in terms of making a 7 1/4" axle bullet proof (go 150,000 miles without breaking). I was wanting to add a Sure-Grip if it is possible, but keep the highway gears. |
| Author: | vynn3 [ Fri Jun 20, 2014 4:57 am ] |
Kelsey Hayes spindles aren't common, but they're not that rare, either. Complete KH brake setups show up on forabodiesonly.com all the time, and I'm sure they pop up on Ebay on a fairly regular basis. Rotors aren't as hard to find as they used to be, either. Several aftermarket companies sell them. The later '73-up brakes also widen the front track, something I've always hated. |
