Slant Six Forum https://slantsix.org/forum/ |
Offy cover breather question https://slantsix.org/forum/viewtopic.php?t=55630 |
Page 1 of 2 |
Author: | JR [ Sun Jun 22, 2014 8:33 pm ] |
Post subject: | |
Baffles are your friend! Otherwise you will have a mess on your hands, on your valvecover, on the side of your engine and on your driveway. http://www.slantsix.org/forum/viewtopic.php?t=55327 |
Author: | Sam Powell [ Thu Jun 26, 2014 1:33 pm ] |
Post subject: | |
I drilled a hole in the top of the Offy cover and put a grommet in it. It took 10 minutes. You can buy the grommet for the PCV first to get your drill bit size. Sam |
Author: | ridehard [ Sun Jun 29, 2014 2:30 am ] |
Post subject: | |
Thanks for the inputs. Cover is away getting baffles welded in and a hole cut for a pcv. Going to run a breather cap in the front and a pcv breather cap in the new hole in the rear. I think this should be a good setup. Cheers |
Author: | 63Valiant [ Sun Jun 29, 2014 6:57 am ] |
Post subject: | |
That slant looks nice! BTW, did you know there's a cat holding your engine up? |
Author: | 65 dartman [ Sun Jun 29, 2014 8:09 am ] |
Post subject: | |
Quote: I drilled a hole in the top of the Offy cover and put a grommet in it. It took 10 minutes. You can buy the grommet for the PCV first to get your drill bit size.
For my 65 I prefer the period correct look with the double stovepipe.Sam |
Author: | xjarhead [ Sun Jun 29, 2014 8:39 am ] |
Post subject: | |
Quote: Quote: I drilled a hole in the top of the Offy cover and put a grommet in it. It took 10 minutes. You can buy the grommet for the PCV first to get your drill bit size.
For my 65 I prefer the period correct look with the double stovepipe.Sam Is there anywhere on this plant to get a stock style metal PCV valve like you show in your photo or do they not go bad and I should just use the one I have? Dave |
Author: | 65 dartman [ Sun Jun 29, 2014 11:04 am ] |
Post subject: | |
Quote: Quote: Quote: I drilled a hole in the top of the Offy cover and put a grommet in it. It took 10 minutes. You can buy the grommet for the PCV first to get your drill bit size.
For my 65 I prefer the period correct look with the double stovepipe.Sam Is there anywhere on this plant to get a stock style metal PCV valve like you show in your photo or do they not go bad and I should just use the one I have? Dave Hi Dave - I've got 3 or 4 brand new metal ones that I bought on eBay. Hope this helps. Edit: I believe they can be cleaned and reused |
Author: | xjarhead [ Sun Jun 29, 2014 11:26 am ] |
Post subject: | |
Ok thanks Dave |
Author: | xjarhead [ Sun Jun 29, 2014 11:46 am ] |
Post subject: | |
They are quite salty on Ebay arent they. Dave |
Author: | 65 dartman [ Sun Jun 29, 2014 12:47 pm ] |
Post subject: | |
Yes, they can be |
Author: | ridehard [ Wed Jul 02, 2014 3:21 pm ] |
Post subject: | |
So the breather and pcv breather have been ordered. Billet specialities ones are on their way. Baffles are being done as we speak and while the cover is away at a guys welding shop I am going to get his paint guy to paint inside the fins black. Can't wait. The engine is all wired up in a run in stand now and just waiting for the starter motor before firing it up for the first time. Running an edelbrock thunder series 500 and wondering if anyone has had any experience with them? I'm hoping to get it pretty well tuned before putting it in the car. Thanks! |
Author: | '67 Dart 270 [ Wed Jul 02, 2014 9:18 pm ] |
Post subject: | Omg |
First, Ridehard, your engine looks awesome with that chrome and polish!!! I too went with dual stovepipe (see link to pic below) http://s785.photobucket.com/user/67dart ... f.jpg.html It was a bit pricey, as I had a machinist weld in the stove pipe and powder coat the cover. But, I only had a baffle put in the rear (new) stove pipe. On the front there is none, and due to the airflow pattern, there is no oil issue up front, clean and oil free always. But as one member mentioned you could simply drill a hole, use a grommet and an off the shelf breather with a screen and filter element. There's a link to this set up on the boards, very economical and works fine apparently. Brian |
Author: | olafla [ Sun Jul 06, 2014 5:34 pm ] |
Post subject: | |
You could go for a nice loking aluminum catch tank, and skip the pcv valve in the breather cover. Just use any breather that looks good - there are plenty chromed examples to choose from, and place the pcv valve in the catch tank instead. See this thread for suggestions: http://www.slantsix.org/forum/viewtopic ... ht=#393270 BTW: I don't intend to discourage you, but you may have been too creative when it comes to baffles, remember that you have to use the front opening for oil filling as well. Olaf |
Page 1 of 2 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
