It is currently Wed May 13, 2026 9:21 pm
 Post subject: emissions w00ws in pa
PostPosted: Sun May 04, 2014 5:17 am
any one else in pa 75 dodge..need answers on emissons ...cat,smog,canisters :?
new owner of a 1975 dodge street van seeking wisdom from other slant 6 owners
PostPosted: Sun May 04, 2014 5:56 am
depends on which county you live in
PostPosted: Sun May 04, 2014 7:08 pm
it also depends on if it's a car or a truck.
some continues have emissions others not..
if they do have emissions in your county it will have to pass a visual.. that meaans tht if it cme with egr ANd charcoal canisters etc.. then they need to be there.
their functionality could be questionable.
I live in a county with emissions..
how wowed out cats and egr valves with a plate or gasket in between the manifold and rh valve have passed for me.
to find out if you have emiss. in your county go to any state inspection garage etc.. and ask if the emissions are required.
PostPosted: Mon May 05, 2014 11:06 pm
thanks ,but can't seen to find out what the original emissions equipment is for it, have all 74-75 mopar manuals and mopar parts catalog ...but how do i find out what emissions equipment the van was orginally sold with... 75 dodge b100 base model 225 slant ...no power anything...was there a cat, smog pump ,char canister .....and theres no sticker under hood
PostPosted: Tue May 06, 2014 5:20 am
I maybe all wet, but I recall non California spec. (49 state) light truck pollution controls lagged passenger vehicle standards by one or more years in mid seventies. I would think there should be a PCV diagram, and charcoal canister pluming decal under hood of your truck when it left the factory, and in FSM; both devices which were integrated into cars by late sixties.
Maybe some sheet metal was replaced, and or repainted at some point leaving off or covering any factory decals, or those markings were not mandated for trucks.
PostPosted: Tue May 06, 2014 8:57 am
No.. None of that stuff on 75 trucks / vans... They didn't get any of that until 78-9
My 77 truck has no egr .. no cat... no Vapor can at all.. It was like that from the factory.
It will have a Breather that vents to the Air filter and a PCV system.. but that's all.
PostPosted: Mon Jun 16, 2014 10:06 pm
thanks guys...
