It is currently Thu Jun 11, 2026 5:02 pm
 Post subject: Removing a Starter
PostPosted: Fri Jun 27, 2014 2:46 pm
I'm sure I am making this a lot harder than it is supposed to be, but I am having one heck of a time removing the bottom nut from the stud that holds the starter to the bellhousing. The top bolt unscrewed with some difficulty also, but at least it would budge. I applied some PB Blaster to the stuck offender in hopes it would eat through years of rust, but it has not helped. Suggestions welcomed. I can't seem to get a tool on the nut and use the leverage necessary to give the nut a twist or two. Thank you.
PostPosted: Fri Jun 27, 2014 4:39 pm
What tool(s) have you tried?
If its rust, you may want to soak it, let it sit (maybe overnight), and soak it some more. Get a good sized closed end wrench on it, or a socket, ratchet and short extension to bring you out just beyond the starter....
Should be pretty straight forward... Hopefully theyre not cross-threaded on there or you'll be fighting it with every little turn.
"if it aint broke, fix it till it is"
78 Plymouth Volare Super Six wagon
89 Volkswagen Golf GTI 16v
92 Chevrolet K1500 5.7
98 Ford Escort ZX2 zetech
 Post subject: Starter Removal
PostPosted: Sun Jun 29, 2014 12:21 pm
Well, I finally got the starter bolts removed, but another problem has developed. I guess the starter was an original since it has no intention of being removed. I smacked the starter pretty good a couple of dozen times, and used a major pry bar to try and loosen things up, but to no avail. Ideas?? Thanks.
PostPosted: Sun Jun 29, 2014 12:29 pm
A block of wood and a quick firm rap with a big hammer. I would lay something soft under it too catch it and break its fall if you care at all about re-using it.
PostPosted: Sun Jun 29, 2014 5:32 pm
Finally...starter is off! Turns out it was almost welded to the bell housing, a condition caused by excessive corrosion. I used a long pry bar and a lot of sweat in removing the starter. I think it may have been the original starter! After a lot of clean up and scraping, I managed to put in the new starter without any difficulty. Thanks to all who waded through my previous questions and pleas for help.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
