It is currently Thu May 28, 2026 2:23 pm
 Post subject: fuel pump pick up
PostPosted: Sat Jul 05, 2014 8:14 pm
Hi guys, wanted some advice when installing a in tank electric fuel pump ( new stealth 340 pump) how much clearance should there be between the bottom of the filter sock and bottom of the tank ??
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sun Jul 06, 2014 5:28 pm
43 looks and no replies ?? c'mon guys how far off the bottom of the tank should this be ??
-Mike
PostPosted: Sun Jul 06, 2014 6:32 pm
in the ones ive changed over the years the sock just touched the bottom of the tank. ive had a couple 90's car that were actually spring loaded when you put the assembly in so you had to push down to lock the ring. so pretty much as close to the bottom as you can get it and still maintain flow.
PostPosted: Sun Jul 06, 2014 8:23 pm
thanks Junior, i figured as much, its kinda hard to see inside the sock to get an idea on how close you can get
PostPosted: Sun Jul 06, 2014 8:27 pm
i would get it as close to the bottom as you can. assuming the tank is clean you shouldnt have any problems.
1966 Plymouth Valiant, 225, 3 on the tree, 8 1/4 3.21 sure grip, hyperpac, holley 650dp, holset h1c
