83 Slant 1bl carb problems
https://slantsix.org/forum/viewtopic.php?t=55773
Author:  Skully [ Fri Jul 11, 2014 7:56 pm ]
Post subject:  83 Slant 1bl carb problems
I have been driving an 83 D150 slant since Feb 2014. Just recently idle speed dropped and began getting sluggish and stalling when warm. Believe carb is holley 1945 1bl. Fuel/air screw missing and cant figure out if that is the only prob. When stalls, seems like its choking itself out. Also has a lot of run-on (dieseling effect) not sure what else to do besides rebuild. Don't know settings for carb.
Author:  Rick Covalt [ Sat Jul 12, 2014 1:20 pm ]
Does it have the lean burn stuff still on it?
Author:  Reed [ Sat Jul 12, 2014 2:10 pm ]
Post subject:  Re: 83 Slant 1bl carb problems
Are you sure it isn't just hidden behind the factory concealment plug?
Dieseling is usually a timing problem.
I second the question "Does it have the lean burn stuff still on it?" A failed lean burn system can cause exactly the symptoms you describe.
Author:  Skully [ Sat Jul 12, 2014 2:27 pm ]
Post subject:  83 Holley 1945
Positive. The idle mixture screw and cap are not present. Not sure what size. been driving it since Feb and had occasional run-on but now more so. Distributer is tight (hadn't been touched)
When truck runs for about 10 minutes it sputters out and is hard to start. must sit b4 starting again
