It is currently Sun May 24, 2026 2:10 pm
 Post subject: Leaky Carb
PostPosted: Thu Jul 10, 2014 11:11 am
Short and simple, my 72 Valiant has a leaky carb and I need some suggestions, My grandfather says after I drive it for a while it may seal up, but my uncle believes I should just rebuild it (My whole family is a Mopar family). I want to think my grandfather would be right because with age becomes wisdom, but I want to hear from you guys what you believe I should do. I don't know what kind of Holley it is. I've only rebuilt an ATV carb before so I have little experience. Thanks in advance,
Kyle
Here is the carb. The arrow points to where it leaks.
1972 Plymouth Valiant (225 Stock)
1994 Isuzu Amigo XS (2.6L Farm Truck)
PostPosted: Thu Jul 10, 2014 1:58 pm
That is a 1920 Holley, you can barely make out the carb numbers stamped on the air vent.
Go to the Engine FAQ section and down load the manual.
Correct float height and installing a new needle and seat will help.
PostPosted: Thu Jul 10, 2014 2:04 pm
The link to the 1945 manual is broken, do you have the manual or another link to it?
Thanks!
1970 D100 "Dude"
SL6 / 3 speed manual
PostPosted: Thu Jul 10, 2014 2:31 pm
http://www.slantsix.org/forum/viewtopic.php?t=33102
or, more specifically,
Here is the Holley 1920 operation and repair manual. Discussion threads about 1920 repair are here, here, and here, and there's a big discussion thread about 1920 modification & upgrade here.
PostPosted: Thu Jul 10, 2014 2:37 pm
Try here: http://www.carburetor-blog.com/holley-1920-carburetor/
1964 Dart GT
PostPosted: Thu Jul 10, 2014 2:44 pm
Huh. Looks like all of the carb manual links are broken. Looks like Dan pulled the plug on the U225 site?
PostPosted: Thu Jul 10, 2014 2:53 pm
Mikes carb's has them http://www.carburetor-parts.com/Free-Ca ... p_274.html
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Thu Jul 10, 2014 6:34 pm
Again that is a 1920 Holley......
The needle and seat are shot if it leaking up there!
If it is leaking that high the float setting is way off.....
Reset per the instructions per the rebuild kit......
My preference is the Walker Kit.
If you don't want to buy a kit, just get the needle and seat and set the float level. This takes about 10 minutes to install and set correctly. You can do it while it is on the car.
PostPosted: Mon Jul 14, 2014 12:44 pm
Thank you for your help all, I am going to rebuild it.
PostPosted: Mon Jul 14, 2014 8:16 pm
Holley_model_1940_and_1945.pdf
Olaf
Aspenized
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
