It is currently Sat Nov 21, 2026 5:56 pm
 Post subject: Wire GA Help Needed
PostPosted: Wed Jul 16, 2014 5:03 pm
I am beginning to put together an HEI conversion setup for my 63 Valiant. Today I received the recommended electronic distributor to go along with other parts I've collected from another member on this board. Other than a post setting out the wire gauges to use when using a relay, I've not seen anything on what gauge wire to use elsewhere such as connecting the distributor to the HEI 4-pin module, module to the coil, etc. etc. Hopefully, one of you can help me. Thank you.
PostPosted: Wed Jul 16, 2014 5:48 pm
14 AWG is plenty and 16 AWG would be fine on the power side. The signal from the distributor can be 16 or 18 AWG.
PostPosted: Wed Jul 16, 2014 6:14 pm
Thanks...
