It is currently Thu Nov 12, 2026 10:18 pm
PostPosted: Wed Jun 04, 2014 6:14 am
AFter doing an auto tune run, the cells that were changed show up, and former values can be read by hovering over the cell with your mouse. This lets you know which were the unchanged cells, and which ones to change in evening out the VE chart. However, when you turn off the engine these changes disappear and there is no way of telling which cells are the calculated values, and which ones are the old incorrect ones. This means you must let the engine sit there and idle while you check things out. Or so it seems. Is there a way of seeing the latest auto tune configuration after shutting down the engine?
Sam
