| short (altered) wheelbase daily driver? https://slantsix.org/forum/viewtopic.php?t=55892 |
| Author: | mpgFanatic [ Fri Aug 01, 2014 12:05 am ] |
| Post subject: | short (altered) wheelbase daily driver? |
I got to thinking (dangerous, I know) about how difficult it is to find parking spaces in many urban neighborhoods. A "Smart" Car could be really useful, but I just really don't want to be sitting in anything that small. The issue is length. The 170" sedan fits in many places. The previous 160" car was even easier. An early A-body at almost 190" is not much different than a Volvo 240, which I've discovered requires a winning stroke of good luck in the game of Parking Lotto. Sure, I suppose I could go find a 148" CRX if I wanted to. Or a 175" Volvo Amazon is a serious temptation. But none of those will hold a slant 6. As the brain started smoldering with curiosity, I stumbled upon this old thread wherein lies a fascinating comment: Quote: If I had an extra 4 door A-Body, gas in the welder and extra time on my hands, I would section 30 inches or so out of the middle of the car and make a "short wheelbase" 2 door. (keeping the shorter 4 door, front doors)
Seriously? OK, I know some people can fabricate almost anything, and I admire them. But is this viable? Where would the various cuts be made, in such a way to keep the integrity of the unibody? I've read that the most important points (in the middle) are rockers, transmission tunnel, and roofline. If those were all cut at the same spot, wouldn't it be put together a little like a butt weld? Whereas if the tunnel was cut in the middle, rockers cut near the front, the roof cut near the back, (or vice-versa) would the pieces stack together sort of like building a brick wall, so the original strength of one piece overlaps the cut of the other?Basically cut out the rear doors and back seat area and move the whole rear box forward. Kinda gives you that circus "clown car" look. DD I could imagine the shorter wheelbase adversely affecting handling and stability, especially given the "hang over" percentage of vehicle weight (past the tire contact points) being considerably higher... On the other hand, a Valiant/Dart trunk is big enough to carry the weekly groceries and still swallow half a Honda... No structural degree, here. And I have just enough experience welding and painting to realize I'm not the guy to build this. Thoughts? - Erik |
| Author: | emsvitil [ Fri Aug 01, 2014 3:48 am ] |
Time to photoshop an example............ |
| Author: | emsvitil [ Fri Aug 01, 2014 3:51 am ] |
Do this: ![]() to a A100 van........... |
| Author: | Dart270 [ Fri Aug 01, 2014 6:51 am ] |
I have thought about doing this with an A-body, but maybe remove 8-15" from the middle (butt weld all in one plane) and shorten the trunk section as well. Yes, this would take a lot of time and patience. I would do it for a smaller/lighter package and not for parking. I would also love to chop the top 2" and maybe lower the body down 2" over the subframes for a lower profile and less air resistance. I would not go below about 98" wheelbase or handling would likely go bye bye. Move the engine rearward 2-4" to improve/regain weight balance. If purely for length/parking, I would rig up a non-leaf-spring rear suspension and chop off most of the trunk instead. Much easier for structure removal and fabbing. The "Street Lynx" from RMS (or similar 3 or 4 link) would handle the suspension. I have recently been thinking an old Model A or Plym Sedan street rod would accomplish these same things and be very cool. Much shorter and almost no overhangs. Room for a Slant and a very light package. We'll see... Lou |
| Author: | wjajr [ Fri Aug 01, 2014 7:13 am ] |
Several examples of shortened [url=http://www.bing.com/images/search?q=image+shortened+1978+cadillac+seville&qpvt=imag+shortened+1978++cadillac+seville&FORM=IQFRML]Seville’s here[/url] as an example to strive for. Love those side mounts, and how about the blue ragtop? I recall seeing these altered wheel base “coupes†for sale at Cadillac dealerships in Chicago area in 1978 for big bucks. |
| Author: | Dart270 [ Fri Aug 01, 2014 8:03 am ] |
I saw a really cool Edsel that was shortened and narrowed and dropped at Bonneville Speed Week last year. It was about 2/3 size in every dimension. Dude even drove it on the Salt! Lou |
| Author: | Rick Covalt [ Mon Aug 11, 2014 3:35 am ] |
Move the engine back like Lou said and put he battery in the truck and it should be a wheel stander !!! |
| Author: | Sam Powell [ Mon Aug 11, 2014 5:44 am ] |
I would keep the roof long, and shorten the trunk lid, but not the trunk. You would have a bodacious trunk, and a very long package shelf. OR....... Keep the roof long,and shorten the trunk. You would maybe have to go with coil springs. There is a company that makes such a kit for the A body Mopes that sells for about 2K. I like Serj22's photoshop. That is cool. But you have to move the rear wheels back. Sam |
| Author: | nm9stheham [ Sat Aug 16, 2014 9:05 am ] |
I knew some guys in the old days from the U.P of Michigan who rallied an Olds Toronado with the rear seat area cut out. The short wheelbase was better for turning, but the car was just as wide. Following them on a narrow stage was entertaining, seeing numerous saplings on the road's edge mowed down..... So how about one of the short wheelbase 2DR 2-post Valiants, like a '63? Thinking it was around 183".... SmartCar = TotenKar |
| Author: | 51Cambridge [ Tue Sep 09, 2014 2:07 pm ] |
Quote: Add a straight axel on the front and some wheely bars
