| which A833 to use https://slantsix.org/forum/viewtopic.php?t=5591 |
| Author: | Donram360 [ Sun Apr 27, 2003 10:01 pm ] |
| Post subject: | which A833 to use |
I am definitely pulling the 7-1/4 rear to put in something stronger, so I already know that I will need to cut the driveshaft, but should I put in the long tail all cast iron van tranny, or should I use the short tail like the F bodies would have come with, this one has an aluminum main housing with a cast iron tail? I am building this as a driver/cruiser, not a quarter miler that needs to have every extra ounce shaved off of it. I am leaning towards the van one, the cast iron to absorb any vibrations better, and that would make for a shorter driveshaft also better for a smoother ride. And I would guess that the cast one would be more durable, too. Any thoughts/ideas? |
| Author: | dgc333 [ Mon Apr 28, 2003 10:27 am ] |
I have the long tail shaft A833OD in my 68 Barracuda. Beside the drive shaft length issue you mentioned you will also need to fabricate a mounting plate for the shifter. The front mount is too far forward and the rear one is too far back. On an a-body the I also had to cut off the front most boss on the front mount for cross member clearance and I made an adapter that bolted to the rear mount and positioned the shifter forward to the proper position. |
| Author: | Doc [ Mon Apr 28, 2003 12:01 pm ] |
| Post subject: | More 4-Speed info... |
I would use the A / F Body unit, that will be easer to swap-in. Here is more info. on the differences in the 833's, this article also includes some of Dave's conversion information listed above. DD http://www.slantsix.org/articles/4-spee ... speed1.htm |
