It is currently Tue May 19, 2026 9:06 pm
 Post subject: Choke puloff question
PostPosted: Sun Aug 03, 2014 4:40 am
This is how the choke was set-up when I bought the truck Image
After removing the pull-off I see this Image
Unless I am mistaken this is the late exhaust manifold ( truck is a 73 with engine of un-known year )
Carb is a 1920, what do I need to find to get all of this working again?
Truck is fairly easy to start but I know it would be easier if this were set-up as it should be.
Would one of my choke pull-offs from my 1945 set-ups work. Havent even compared the difference in linkage yet.
PostPosted: Sat Aug 09, 2014 1:36 pm
I got this today Image off a mid sixties Dodge. I dont know if it will work for my 1920 Carb but I do not see why not.
The carb on the car looked very much like the one on my truck.
I do not know up until when they used the 1920 carbs on slants so I am just feeling around for one and bringing home what I think might work.
What do you guys think, surprisingly this one is in very good shape underneath where the spring ect is. Just needs a good blasting on the outside.
PostPosted: Sat Aug 09, 2014 1:50 pm
The early choke (even if the one you found were in good shape, which it isn't) won't work well with the late exhaust manifold. Either get the correct original-type choke for the exhaust manifold and carburetor you're using (in your case, you'd need a relatively scarce 1973-only item, either the truck type without heater or the car type with heater plus the associated choke control module) or save yourself a bunch of fiddling around and nonworking, and get a #1231 Electric choke kit instead.
PostPosted: Sat Aug 09, 2014 3:59 pm
Ill assume it wont work well cause the late exhaust manifold has the open side. Thanks, makes sense
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 19 guests
