| 14.0:1 Head Gasket selection https://slantsix.org/forum/viewtopic.php?t=55927 |
| Author: | Greg Ondayko [ Fri Aug 08, 2014 8:49 am ] |
| Post subject: | 14.0:1 Head Gasket selection |
Can A Fel-Pro or Permaseal AP 210 Be run on a N/A 14:1 Engine? Or is it time for Copper? Just Curious. Thanks, Greg |
| Author: | CNC-Dude [ Fri Aug 08, 2014 9:51 am ] |
It's time for copper and O-ringing at this point. With only 4 bolts per cylinder working against you, composition style head gaskets are futile. |
| Author: | Joshie225 [ Fri Aug 08, 2014 10:06 am ] |
I only went for 13:1 on the 170 I built for Bonneville and I used copper with o-rings. |
| Author: | slantzilla [ Fri Aug 08, 2014 10:11 am ] |
Any time you get above 12-1 on a Slant you are flirting with disaster on standard head gaskets, even with studs. Charlie keeps some copper gaskets I believe. Jim Cox may have some too. |
| Author: | Dart270 [ Fri Aug 08, 2014 10:21 am ] |
I agree copper is going to be the reliable solution. Permaseal with an 0-ring might do it, but likely not long term. Lou |
