| Recent Parts Finds https://slantsix.org/forum/viewtopic.php?t=55937 |
| Author: | Reed [ Sun Aug 10, 2014 10:07 am ] |
2 out of 3 isn't bad. unfortunately, that is a 318 carb that will take a little effort to work on a slant six. Most importantly ou eed to fabricate the adapter for the choke to work correctly. Nice score on that heat shield. Those are getting very hard to find. Any chance you could trace the outline onto a piece of paper and scan the diagram with measurements so others could duplicate the heat shield? |
| Author: | xjarhead [ Sun Aug 10, 2014 11:10 am ] |
[quote="Reed"]2 out of 3 isn't bad. unfortunately, that is a 318 carb that will take a little effort to work on a slant six. Most importantly ou eed to fabricate the adapter for the choke to work correctly. Nice score on that heat shield. Those are getting very hard to find. Any chance you could trace the outline onto a piece of paper and scan the diagram with measurements so others could duplicate the heat shield?[/quote] I second this and im sure others will also. Graph paper might be good to trace it on. Dave |
| Author: | Sam Powell [ Mon Aug 11, 2014 5:27 am ] |
While the choke will require some ingenuity to get working, that is my favorite BBD. It has fully adjustable step up rods,which means you can tailor the enrichment to your engine's needs. When I had that carb on my car with an 833 OD I got between 25 and 29 MPG all the time. Sam |
| Author: | Chief915 [ Tue Aug 12, 2014 6:04 am ] |
I am working on drawing a scaled down picture of the heat shield, with dimensions of course, on graph paper to share with you guys. It's a work in progress, I'm not ignoring the request lol!
| Author: | Chief915 [ Tue Aug 12, 2014 10:22 am ] |
As requested.... here's a drawing and measurements of the heat shield. I'm not an engineer, so try not to make fun lol.
| Author: | Reed [ Tue Aug 12, 2014 10:46 am ] |
That is excellent! Thank you! |
| Author: | xjarhead [ Tue Aug 12, 2014 10:49 am ] |
Thank you very much. Dave |
