It is currently Mon Dec 29, 2025 11:55 am
Post new topic  Reply to topic  [ 30 posts ]  Go to page 1 2 Next
 Post subject: FInding a Super Six
PostPosted: Fri Aug 01, 2014 5:42 am
If I were to go try and find a Super Six setup in a Pick n Pull, which vehicles Should I be looking for?
PostPosted: Fri Aug 01, 2014 5:47 am
I have seen them mostly on mid to late 70's Volares and Aspens. I would think pick-up trucks and vans had them as well.
Happy hunting.
Sam
PostPosted: Fri Aug 01, 2014 10:32 am
Check any Aspen/Volare station wagons- for a few years the 2bbl was standard equipment on slants.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri Aug 01, 2014 11:21 am
I have read that they came in trucks and vans but have yet to see one. Aspen and Volarie. Good luck
PostPosted: Fri Aug 01, 2014 11:31 am
Poser
I have 2 cast iron super six intakes and one of the die cast, welded alum. I think I have a spare BBD and air cleaner. No kick down. PM me if you are interested.
PostPosted: Fri Aug 01, 2014 11:39 am
I got mine from a truck.
The 2 piece welded type.
Had it epoxy coated then powder coated.
Have not had it installed yet.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Fri Aug 01, 2014 10:07 pm
If you find one at a pick-n-pull, get all the linkages all the way to the transmission too. And the air cleaner can.
PostPosted: Sat Aug 02, 2014 12:01 am
The Super Six was "standard" only on 77-80 slant powered passenger car wagons (and slant powered Chryslers of these years). Non-Chrysler brand sedans, coupes, trucks, and vans all had single barrel standard. I have personally seen one factory slant powered van, and I have built a second slant powered van using the VERY rare and hard to find van specific Super Six air cleaner and kick down linkage. I have seen numerous super six trucks.
These days you will be hard pressed to find a factory setup, and if you do it will be expensive and incomplete. You can actually put your own system together using a two barrel intake, a carb, an air cleaner off of a 318, and a cable-style kickdown linkage. The two barrel intake can be made form a modified single barrel intake, and the carb can be pretty much any two barrel carb provided you get an air cleaner for it. If you use a Carter BBD or Holley 2280, you can use a stock 318 air cleaner and buy a reproduction "super six" decal for the lid.
PostPosted: Sat Aug 02, 2014 6:26 am
Thanks for all the information. I was also wondering if there is a difference when it comes to the color of the intake. mine right now is red but I have seen them blue and mostly the ones i have seen were blue online. I have heard the blue is from later years so was wondering it I have to try to find a red one.
PostPosted: Sat Aug 02, 2014 6:27 am
Can you send me pics?
PostPosted: Sat Aug 02, 2014 9:36 am
Poser
If you PM me your e mail address I can send you some pics tomorrow.
PostPosted: Sat Aug 02, 2014 1:54 pm
PM sent
PostPosted: Sat Aug 02, 2014 3:59 pm
I also found this, he is asking 350 and I was wondering if I actually needed all these parts? He is willing to part it. I know I need the intake and carb and cleaner, but what about the distributor and exhaust?
PostPosted: Sat Aug 02, 2014 4:10 pm
6 Pack Dart
Forget the point dist.
Richard
PostPosted: Sat Aug 02, 2014 4:43 pm
He is offering for the air cleaner, carb (supposdly rebuilt) and intake 250 plus shipping, you think it is a fair price? I have no idea what stuff is worth.
Users browsing this forum: Ahrefs [Bot], Majestic-12 [Bot] and 1 guest
