| What intake is this? https://slantsix.org/forum/viewtopic.php?t=55980 |
| Author: | manimal [ Fri Aug 15, 2014 8:54 pm ] |
| Post subject: | What intake is this? |
I have seen the two bbl intakes, but the ones I have seen allhave EGR on them...this does not and it's cast iron. ![]() ![]() ![]()
| Author: | Reed [ Fri Aug 15, 2014 9:25 pm ] |
Export or marine? |
| Author: | SlantSixDan [ Fri Aug 15, 2014 9:30 pm ] |
Marine. Has provisions for a bolt-on waterbox on the underside; has no provision for vacuum tap on #6 runner. |
| Author: | manimal [ Fri Aug 15, 2014 9:45 pm ] |
So would it be a good intake for the street(in a 1/2t truck)? Thank You. and YES I removed from a 225 that came out of a boat. Also have the exhaust heat exchanger manifold with big letters CHRYSLER cast into it. Have NO clue what to do with it! |
| Author: | Reed [ Fri Aug 15, 2014 10:33 pm ] |
D'OH! If I had seen the lack of a vacuum tap I would have nailed it. |
| Author: | manimal [ Sat Aug 16, 2014 6:52 am ] |
So I can only assume this will be a good intake for my truck? I plan on a 833 trans and have manual brakes...so I dont think I need the vacuum tap. |
| Author: | nm9stheham [ Sat Aug 16, 2014 7:39 am ] |
Vacuum runs the heater box controls... but you can get a vacuum tap in other ways. |
| Author: | Junior [ Sat Aug 16, 2014 6:15 pm ] |
yea man its a good intake. |
| Author: | manimal [ Sat Aug 16, 2014 8:30 pm ] |
Thank You! |
