slant throttle rod? 1963 vs 64-5??
https://slantsix.org/forum/viewtopic.php?t=56009
Page 1 of 1
Author:  barbee6043 [ Mon Aug 18, 2014 1:16 pm ]
Post subject:  slant throttle rod? 1963 vs 64-5??
is the throttle rod shorter on the 63 slant dart?
Author:  62 alum [ Wed Aug 20, 2014 8:02 pm ]
The 3 that I have are all 15 in. Long. One is in a 62 valiant and another from a 63 dart both 225s. Forgot what the third is from.
Author:  barbee6043 [ Thu Aug 21, 2014 2:57 am ]
thanks for checking, the "V" pivot is guess is in same location??? mount mounts are the same 63-5????? thanks BILL
Author:  Doctor Dodge [ Thu Aug 21, 2014 8:17 am ]
Vote #2 that they are all the same length...
I have a few also... all the same.
Author:  barbee6043 [ Thu Aug 21, 2014 1:54 pm ]
I don't have the correct short shaft tranny attached to the engine. the long shaft tranny's mounting pad for crossmember is forward and won't work. I have a correct tranny I have to get for it. oint is I can't use the tranny to figure if engine is sitting in correct spot. it will of course sit where the engine mount lets it and I guess I have correct insulators. anyway, ii'm a little stumped right now. thanks for the help. I need to find someone that has a 63 car to measure distance from the firewall to edge of vave cover or to carb throtle busing thingy. thanks again.......
