It is currently Mon Nov 16, 2026 9:47 pm
PostPosted: Tue Aug 19, 2014 4:21 pm
I am trying to identify what rear gear ratio ring and pinion are in the A body 8.25 axle in my brother's Duster. The cover tag is long gone.
The following numbers are stamped into the outer face of the ring gear in this order:
Pentastar
3723584
245
1074
PP
MS
291
HT01
HelixForm3
I figure the 3723584 number is the only one long enough to be a Chrysler part number, ut it doesn't match any 8.25 gearset listed in my 1974 factory parts book. That means that this rear axle must be form some other year a-body. 73, 75, or 76.
I know that Chrysler also stamped the ratio of the gearset into the outer face of the ring gear. If I am reading the numbers right, that means that the gears I have in this axle are either 2.45:1 or 2.91:1. I can live with 2.91:1 gears, but if it is a 2.45:1 I will switch the gears out to the 3.2 gears I have.
Can anyone either (a) check the part number and tell me what gearset I have or (b) tell me if the gears are 2.45 or 2.91:1?
Thanks!
PostPosted: Tue Aug 19, 2014 4:40 pm
Pictures, if they help any.
PostPosted: Tue Aug 19, 2014 4:53 pm
Count the teeth and divide............
:oops:
PostPosted: Tue Aug 19, 2014 5:00 pm
Yeah, but that pinion gear is way back in there and hard to count accurately. I was hoping for a cleaner and easier solution. I am going back out now to see if the ratio is stamped anywhere on the housing.
PostPosted: Tue Aug 19, 2014 5:14 pm
49 ring teeth / 22 pinion teeth = 2.22727273
:cry: Looks like it is a 2.2:1 ratio axle after all.
I am still curious as to why 2.2 is not stamped somewhere on the edge of the ring gear.
PostPosted: Tue Aug 19, 2014 6:19 pm
Never heard of a 2.2
If so, you're screwed......
"From what i understand there is no way to modify the 2.2 or 2.45 carrier. You have to change out the carrier for one that has 2.56 or higher gears. that is why I will look for a 96 or older at a U-pull it."
Bottom of this thread by bill55az 04-21-2011, 08:38 PM
http://www.aspenandvolare.com/archive/i ... 903616e713
PostPosted: Tue Aug 19, 2014 6:53 pm
Right, that is why I got the carrier for the 3.2 gears when I bought the gears. I purchased everything out of the center section of the axle.
PostPosted: Tue Aug 19, 2014 7:54 pm
2.2:1 was the "economy"/CAFE compliance attempt option for axles in V-8 powered cars.
