| Park Cover Gasket https://slantsix.org/forum/viewtopic.php?t=56014 |
| Author: | jhdeval [ Tue Aug 19, 2014 7:45 am ] |
| Post subject: | Park Cover Gasket |
I have ordered the park cover gasket http://www.ebay.com/itm/370930456659?ss ... 1423.l2649 What I am wondering is does the transmission need to be drained? |
| Author: | jhdeval [ Wed Aug 20, 2014 11:11 am ] |
Anyone? |
| Author: | sixinthehead [ Wed Aug 20, 2014 1:33 pm ] |
If you lift the rear of the car to do the work, you won't lose very much fluid, maybe a quart or two. Use stands under the rear axle and lift it as high as safely possible. You'll still need a drain pan, but most of it will stay in the converter. Then just top it off when you're done. |
