| A body 8.25 gear and pinion identification help needed https://slantsix.org/forum/viewtopic.php?t=56016 |
| Author: | Reed [ Tue Aug 19, 2014 4:21 pm ] |
| Post subject: | A body 8.25 gear and pinion identification help needed |
I am trying to identify what rear gear ratio ring and pinion are in the A body 8.25 axle in my brother's Duster. The cover tag is long gone. The following numbers are stamped into the outer face of the ring gear in this order: Pentastar 3723584 245 1074 PP MS 291 HT01 HelixForm3 I figure the 3723584 number is the only one long enough to be a Chrysler part number, ut it doesn't match any 8.25 gearset listed in my 1974 factory parts book. That means that this rear axle must be form some other year a-body. 73, 75, or 76. I know that Chrysler also stamped the ratio of the gearset into the outer face of the ring gear. If I am reading the numbers right, that means that the gears I have in this axle are either 2.45:1 or 2.91:1. I can live with 2.91:1 gears, but if it is a 2.45:1 I will switch the gears out to the 3.2 gears I have. Can anyone either (a) check the part number and tell me what gearset I have or (b) tell me if the gears are 2.45 or 2.91:1? Thanks! |
| Author: | Reed [ Tue Aug 19, 2014 4:40 pm ] |
Pictures, if they help any. ![]()
| Author: | emsvitil [ Tue Aug 19, 2014 4:53 pm ] |
Count the teeth and divide............ |
| Author: | Reed [ Tue Aug 19, 2014 5:00 pm ] |
Yeah, but that pinion gear is way back in there and hard to count accurately. I was hoping for a cleaner and easier solution. I am going back out now to see if the ratio is stamped anywhere on the housing. |
| Author: | Reed [ Tue Aug 19, 2014 5:14 pm ] |
49 ring teeth / 22 pinion teeth = 2.22727273 I am still curious as to why 2.2 is not stamped somewhere on the edge of the ring gear. |
| Author: | emsvitil [ Tue Aug 19, 2014 6:19 pm ] |
Never heard of a 2.2 If so, you're screwed...... "From what i understand there is no way to modify the 2.2 or 2.45 carrier. You have to change out the carrier for one that has 2.56 or higher gears. that is why I will look for a 96 or older at a U-pull it." Bottom of this thread by bill55az 04-21-2011, 08:38 PM http://www.aspenandvolare.com/archive/i ... 903616e713 |
| Author: | Reed [ Tue Aug 19, 2014 6:53 pm ] |
Right, that is why I got the carrier for the 3.2 gears when I bought the gears. I purchased everything out of the center section of the axle. |
| Author: | Reed [ Tue Aug 19, 2014 7:54 pm ] |
2.2:1 was the "economy"/CAFE compliance attempt option for axles in V-8 powered cars. |
