| uneven rear end https://slantsix.org/forum/viewtopic.php?t=56039 |
| Author: | '67 Dart 270 [ Sat Aug 23, 2014 6:20 pm ] |
| Post subject: | uneven rear end |
I replaced my old 7.25 for an 8.75 and ESPO leaf springs at the same time. The ride is a bit stiff, but it's much more stable back there. The height is uneven, one side is a bit higher than the other, about 3/4 inch. ESPO says they take great measures to make sure their springs are matched. Anybody have this issue? Best way to even it out? Do I put a heavy weight in the trunk on the higher side for awhile or what? thanks all, Brian |
| Author: | Reed [ Sat Aug 23, 2014 6:42 pm ] |
Relocate the battery to the high side? |
| Author: | Rick Covalt [ Sat Aug 23, 2014 7:16 pm ] |
Maybe when you set in the car it is even? |
| Author: | emsvitil [ Sat Aug 23, 2014 7:24 pm ] |
Did you tighten the bushing bolts when the car was jacked up? |
| Author: | '67 Dart 270 [ Sat Aug 23, 2014 10:38 pm ] |
| Post subject: | bushing bolts |
I didn't install the springs, but do you mean to suggest the bushing bolts are too tight, I don't think that's the issue. |
| Author: | emsvitil [ Sat Aug 23, 2014 11:44 pm ] |
You tighten rubber bushings when the vehicle is on the ground. Otherwise they act like a torsion bar (raising the vehicle a little) until they rip apart internally. |
