It is currently Sat Mar 01, 2025 2:35 pm
 Post subject: cam replacement time
PostPosted: Thu Sep 04, 2014 6:44 am
I was wondering if anyone knew a flat rate time to replace a cam?
does anyone have a flat rate time for swapping a cam on the slant six?
PostPosted: Thu Sep 04, 2014 7:14 am
Engine in the car or out?
PostPosted: Thu Sep 04, 2014 7:40 am
More info would be helpful because it is unusual to just replace a camshaft alone... unless you want to do it for a performance change / power improvement.
Said another way...
A camshaft replacement is a big job so you may want to do a full engine rebuild or replacement, if you are working with a high mileage engine.
PostPosted: Thu Sep 04, 2014 6:54 pm
Thanks for the replies. The job is an in the car swap a 1976 Duster auto. I'm installing a Clifford intake and headers also recurving the distributor.
PostPosted: Fri Sep 05, 2014 10:58 am
I pulled a labor time for Apen/Volare- 7.0 hours + .3 for A/C. ( you have to pull the head to get the lifters out with the 75-up peanut plugs)
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri Sep 05, 2014 1:51 pm
Yup.
Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 18 guests
