It is currently Tue Dec 30, 2025 1:46 pm
PostPosted: Fri Sep 19, 2014 3:48 pm
Just tore down my 68 . I noticed that #3 has no oil hole.
Is this normal? If not should I drill?
Thanks in advance
PostPosted: Fri Sep 19, 2014 3:50 pm
Sorry . The missing hole on the big end of the rod.
PostPosted: Sat Sep 20, 2014 5:29 am
No oil spurt hole in a factory con rod is a factory mistake... it should be there.
having one missing hole is not a "show stopper for an ol'SL6... the other 5 will "cover".
If you are rebuilding the engine, either replace that con rod or drill the missing hole.
PostPosted: Sat Sep 20, 2014 12:32 pm
Thanks !!!
Going to get machine shop to add hole.
Users browsing this forum: Bing [Bot] and 22 guests
