It is currently Fri Nov 20, 2026 11:37 pm
 Post subject: speedometer stuck
PostPosted: Sat Sep 06, 2014 11:55 am
hey guys my speedometer works but it starts from 35mph instead of 0 when i turn off my car the needle will not go down back to zero, it only resets back to 35 mph.. i have no idea what to do. it seems to climb higher and higher it used to go back to 30 then it started creeping up to 35mph
1970 Dart Swinger Matching Numbers..
PostPosted: Mon Sep 08, 2014 5:40 pm
On my 75's I have opened the speedometer (factory sealed) and messed with them. Sounds like yours may be worn out bearings. Can't help you there. Also could be a small bit of crud in the needle/hairspring mechanism. Very delicate. I might try opening the unit and cleaning out the mechanisms with a spray can of "electrical contact cleaner"- not lubricant, not corrosion preventative. Just a plain cleaner, if you can find something like that. Be careful not to get any spray on the speedometer face or needle. Anyone else have ideas?
PostPosted: Tue Sep 09, 2014 9:40 am
thank you will try this weekend
PostPosted: Tue Sep 09, 2014 6:51 pm
Electrical contact cleaner will really mess up plastic; better off to use just alcohol, IMO. Have had this issue; seemed to be a bad return spring or bearings or such as mentioned above. Replaced the cluster; never tired to open and fix so can't say how hrad or easy that may be.
PostPosted: Wed Sep 10, 2014 1:19 pm
Alcohol would work, I think. But again, keep it off the plastic. The way I clean them out, I open the sealed unit to get to the bearings, magnetic drum, and hairspring.
