| Help finishing super six swap https://slantsix.org/forum/viewtopic.php?t=56186 |
| Author: | amschnellsten [ Sat Sep 13, 2014 9:06 am ] |
| Post subject: | Help finishing super six swap |
HI, I have been trying to finish up a super six manifold swap on my 71 Duster and I finally got around to putting it together and realized I am missing some critical parts. I have the whole linkage part that bolts to the manifold and the long rod that runs down for the kick down. I am missing the parts where the rod is connected to the trans. I think I am missing the spring, the bolt pivot piece and maybe the specific arm for the trans. Is the arm on the trans itself different? I also noticed the pivot for the shifter linkage looks like it may be the same as the part for the kick down rod, Is it? I have checked the salvage yards around here and can't find any early model cars at all. Please please let me know if anyone has these pieces and I want them bad! Or if anyone has any ideas for a solution. I don't want to do a lockhart cable ext because I almost have everything. |
| Author: | Josh P [ Sun Sep 14, 2014 8:16 pm ] |
I don't think you're missing any pieces, but others should chime in if I'm wrong. At the bottom of the long super six kickdown is a spring and the bolt pivot piece. The arm is not specific. The bolt pivot is the same as the non-super six piece so you should be good to go. |
| Author: | amschnellsten [ Mon Sep 15, 2014 3:00 pm ] |
maybe Im not looking at it right. Ill have to double check but I don't remember seeing a spring or pivot and the old arm is still attached? |
| Author: | amschnellsten [ Wed Sep 17, 2014 5:46 am ] |
I climbed under again and the kick down rod connection is different. The old set up is just a rod bent with a cotter pin. So I need the spring and pivot. If anyone has these I'll pay big bucks!!! |
| Author: | /6 Matt [ Thu Sep 18, 2014 6:54 pm ] |
Post in the parts wanted section too and you might have better luck. I wish I could help but I went the bouchillon route. |
| Author: | amschnellsten [ Fri Sep 19, 2014 2:48 am ] |
Does that work on the bbd carb ? |
| Author: | Reed [ Fri Sep 19, 2014 11:59 am ] |
You may want to try switching to a cable style kickdown. You can get them for under $30 on eBay. |
