It is currently Fri Nov 20, 2026 11:56 am
PostPosted: Mon Sep 22, 2014 2:39 am
http://www.csi-ignition.nl
Came across this system today. Is there a place for it on a slant 6 ?
1967 VC Valiant
PostPosted: Wed Sep 24, 2014 9:22 pm
Looks kind of like a Mallory electronic advance distributor packaged in a Lucas housing. While the concept certainly has some benefits- you're looking at some fairly serious coin. A dist recurve & HEI would give you most of the performance at a fraction of the cost- just not the multiple advance curves.
63 Valiant Wagon
225 - 4 bbl
 Post subject: x2
PostPosted: Sat Sep 27, 2014 1:40 pm
Looks to be similar to mallory or the petronix unit...the EI distributor will be much more flexible in curves and gives rock solid timing.
