| Antisway bar (64Dart) https://slantsix.org/forum/viewtopic.php?t=56306 |
Page 1 of 2 |
| Author: | moparfarr [ Tue Sep 30, 2014 6:30 pm ] |
| Post subject: | Antisway bar (64Dart) |
Whats the hot setup to put an antisway bar on the front of my 64 Dart ?Anybody done it and have a recommended company to get ahold of ? (SL6 powered of course) |
| Author: | Reed [ Tue Sep 30, 2014 7:18 pm ] |
Last I head Addco was about the only game in town for aftermarket sway bars, unless you get really luck and find a factory swaybar setup. I may be wrong though. |
| Author: | Doctor Dodge [ Tue Sep 30, 2014 7:34 pm ] |
What is "hot" for you... Super good handling performance or ease of installation? DD |
| Author: | Michael [ Tue Sep 30, 2014 8:10 pm ] |
X2 with the Doug's comment. Spend a bit more and get yourself the Firm Feel Tubular set-up: http://www.firmfeel.com/a_body_mopar_fr ... bular.html It is an amazing unit!!! |
| Author: | emsvitil [ Tue Sep 30, 2014 9:31 pm ] |
The rear mount for the Addco bar is fine. The front mount for the Addco bar sucks. I improved the front mount to make it acceptable. (for less cost than the firmfeel setup) |
| Author: | emsvitil [ Tue Sep 30, 2014 9:37 pm ] |
Some previous threads on the mounts http://slantsix.org/forum/viewtopic.php ... unt#304376 http://slantsix.org/forum/viewtopic.php ... unt#301100 |
| Author: | moparfarr [ Wed Oct 01, 2014 1:38 pm ] |
looking for good handling the most. I have some talented people to help install it. I just spotted a Hellwig bar in the Jegs catalog for around $270 seems a little pricy hopefully it is a better fit than the Addco bar |
| Author: | Dart270 [ Wed Oct 01, 2014 2:15 pm ] |
Firmfeel will likely be better than Hellwig, and about that price. Addco will require some hours of fab time with a welder and some plate/angle steel. Lou |
| Author: | WagonsRcool [ Fri Oct 03, 2014 6:47 pm ] |
Now you made me curious- I'll have to crawl under the front of my 63 Valiant & see what I did years ago. It was an Addco bar & their tinker-toy mount setup never made it onto the car. I recall doing a fair bit of welding & fabricating. I'll see on Monday. |
| Author: | 65 dartman [ Sat Oct 04, 2014 7:49 am ] |
There's a Guy over at FABO selling a Helleig bar for an early A. I bought one for my wagon and looks like it will be pretty easy to install, especially using factory LCAs with the correct sway bar tab. |
| Author: | 63valconvert [ Sun Oct 19, 2014 12:06 pm ] |
Quote: X2 with the Doug's comment. Spend a bit more and get yourself the Firm Feel Tubular set-up:
Michael is totally right. I put mine on my 63 and WOW. What a difference.http://www.firmfeel.com/a_body_mopar_fr ... bular.html It is an amazing unit!!! Takes a tiny bit of modification, but amazing bar. |
| Author: | moparfarr [ Wed Oct 22, 2014 8:32 am ] |
Thanks everybody I forgot to add that I switched over to the 69-72 small bolt pattern Disc Brakes. Does that change anything ? |
| Author: | WagonsRcool [ Wed Oct 22, 2014 1:29 pm ] |
It depends- you usually can't fit a front sway bar to a narrow body A with discs unless the calipers are mounted to the rear of the spindle. I don't recall the sbp K-H disc setup. I went with lbp single piston discs- that required swapping the spindles L-R to get the calipers towards the rear. |
| Author: | MOUSETRAP [ Mon Dec 22, 2014 10:06 am ] |
So if you do a LBP disc brake swap from 73-76 abody into a early 63-72 abody to use a sway bar the calipers need to be mounted to the rear of the rotor ?. What is needed for this ? I read look out for brake lines ? I will be putting braided lines on . Then install either firm feel sway bar Or hellwig sway bar Thanks smitty |
| Author: | sixinthehead [ Mon Dec 22, 2014 12:06 pm ] |
I have 74 discs on my 65, calipers front, and used an Addco bar. I bent the ends of the bar inward slightly (1"ish) which cleared the calipers and gave me a better end-link angle to boot. There's always going to be a little 'fine-tuning' needed on any install, but it's nothing that can't be done. Lots of options... |
| Page 1 of 2 | All times are UTC-07:00 |
