Fuel guage ground strap
https://slantsix.org/forum/viewtopic.php?t=56319
Author:  crickhollow [ Sat Oct 04, 2014 4:40 am ]
Post subject:  Fuel guage ground strap
My 62 Valiant uses the metal ground strip.
Is there a better solution to ground the sender unit than using the metal strip?
Author:  nm9stheham [ Sat Oct 04, 2014 7:21 am ]
How about a terminal on a wire to put onto the sender tab, and then a ring terminal on the other end with a sheet metal screw direct to chassis?
Author:  SlantSixDan [ Sat Oct 04, 2014 11:20 am ]
Post subject:  Re: Fuel guage ground strap
H'mm. A solution better than the metal clip strap which has worked fine on your Valiant and zillions of other cars like it for over half a century. H'mm.
Sorry, I got nuthin'. :shrug:
Author:  nm9stheham [ Sat Oct 04, 2014 12:42 pm ]
Now you got me to wondering what are the symptoms/issues experienced by the OP....
Author:  phogroian [ Fri Oct 10, 2014 1:58 pm ]
If you don't have the clip, a length of the woven steel sheathing that surrounds good quality coax cable can be clamped to the sender.
Author:  crickhollow [ Sun Oct 12, 2014 2:19 am ]
Thanks for the feedback. I "worked" on the strap to get a good ground on the fuel line and now my guage reads OK.
Author:  69a100 [ Sun Oct 12, 2014 6:41 am ]
I had the same problem and used a couple pieces of wire hose clamped together. That worked for awhile then died. Then I cleaned the dirt and gunk and sanded the lines and installed a new clip and presto, life's been good ever since. Glad ya fixed it!
