Custom exhaust pricing
https://slantsix.org/forum/viewtopic.php?t=56353
Page 1 of 2
Author:  hideogumperjr [ Thu Oct 09, 2014 11:43 am ]
Post subject:  Custom exhaust pricing
Just Got an estimate from Muffler King here in Kirkland, Wa for $650.00 to install 2.25" from manifold back using my own muffler and 2.00" from muffler to their resonator out.
Thought I had seen many folks saying they paid less.
Anyone make comparison costs or have suggestions?out
Thanks all.
John
Author:  Reed [ Thu Oct 09, 2014 12:25 pm ]
Wow, I hope they at least buy you dinner first! $650 is pretty steep for a custom single exhaust pipe.
The last time I had a completely custom dual exhaust system put together was about twelve years ago. I believe it cost around $400 for the labor, pipe, and mufflers. I went to a ocal independent muffler shop.
If you have access to a welder or a friend who welds, you can buy pre-bent pieces of pipe and weld up your own exhaust system. That is what I intend to do on my brother's Duster. Otherwise, my only recommendation is to put in the leg work and shop around.
Author:  vynn3 [ Thu Oct 09, 2014 12:33 pm ]
I paid $250 for 2" duals all the way back from the Dutra manifolds, with my own mufflers.
Now, granted, it's a crappy, poorly-designed exhaust system, but at the time I wanted the car back on the road, and it's all I could afford.
Still, it's (mostly) held together for 5-6 years. A new, well-built system is high on my list of future projects.
Try a smaller, mom-and-pop exhaust shop, as opposed to Midas. Most will do pretty good work.
Author:  Rick Covalt [ Thu Oct 09, 2014 12:56 pm ]
It should be gold plated for that! :lol: And no mufflers!! Check around where the guys that drag race go. They will know someone and they will be much less than that!
Author:  hideogumperjr [ Thu Oct 09, 2014 3:33 pm ]
Thanks Folks. Dang Reed why are the more reasonable places down the Tacoma!?!
Ill check around more to compare and keep yall posted.
Cheers.
Author:  hideogumperjr [ Thu Oct 09, 2014 4:28 pm ]
just talked to a guy at Shoreline Muffler who said it would cost around $250. Much better sounding!
Author:  Greg Ondayko [ Thu Oct 09, 2014 5:23 pm ]
get a hot saw, tubing straights, bends, clamps, and mig weld it yourself!
if you get resourceful, do it once in stainless
Author:  hideogumperjr [ Thu Oct 09, 2014 7:44 pm ]
Got a metal cutting saw and a mig welder but getting access under the car would prove to be the most difficult. Sides I watched those car shows where the do that and well, it would most likely come out looking like a shoeshine box.
Older folks will understand that!
Author:  Reed [ Thu Oct 09, 2014 8:02 pm ]
I plan on putting my brother's Duster up on ramps and jack stands and test fit the pipes from the front to back, on e section at a time, tack welding the pieces together, then removing the pipes from the car for the final welding. Time consuming and repetitive, but I have a sawzall, a welder, and a pile of used exhaust pipes to play with. Unless I can save up a few hundred dollars. Then I will just pay someone else to do it. :wink:
Author:  Dart270 [ Fri Oct 10, 2014 3:21 am ]
DON'T go too cheap. Try to find someone in the area with personal, positive experience with a place that does custom work. I usually search around and find a place and take 1/2 day off and go there to give advice while they are doing it (without, hopefully, being too annoying to them).
At the moment, my good place is 45 min away in Salem, VA, and he would probably charge $300 for such a job, with muffler.
Author:  Greg Ondayko [ Fri Oct 10, 2014 4:02 am ]
Putting it together involves finding the angles and clocking of the tubes under the car tack welding the pieces - checking for fitment and interference - Lotsa mock up.... then remove and fully weld in a comfortable position on a bench etc....then reinstall when fully welded.
Author:  nm9stheham [ Fri Oct 10, 2014 6:04 am ]
I've done the weld up with angles etc., and my expereience its that the welds and joints present more opportunites for rust out and have found the bent pipes tend to last better in general. Of course, if your car is not driven in rain or salt, then it'll probably be OK for quite a while.
Author:  slantzilla [ Fri Oct 10, 2014 9:00 am ]
As said before, find a Mom and Pop place with a pipe bender. I have a buddy with his own shop who would do that system all day long in 2" or 2-1/4" for $200, and that includes a muffler. :shock:
Author:  dartsport76 [ Fri Oct 10, 2014 9:47 am ]
The local mom and pop shop here did dual 2" exhaust (supply yur own mufflers) and an inspection for 200
Author:  vynn3 [ Fri Oct 10, 2014 10:13 am ]
Although it will lack that "Midas Touch"... ;)
Page 1 of 2 All times are UTC-07:00
