| Crank Bolt https://slantsix.org/forum/viewtopic.php?t=5637 |
| Author: | NORM [ Fri May 02, 2003 8:13 am ] |
| Post subject: | Crank Bolt |
Can anyone tell me the specs on torqueing the crank bolt in front of the slant 6? |
| Author: | Chuck [ Fri May 02, 2003 10:03 am ] |
I don't know what the torque spec is, but the bolt is just used to install the damper. I have only seen 1 or 2 slants with the bolt left installed. |
| Author: | Slant Cecil [ Fri May 02, 2003 1:37 pm ] |
The slant six takes the same size bolt as the big and small block Mopars. Their torque spec is 135 lbs. Cecil |
