| Z-bar sliding laterally when shifting Where to get bushings? https://slantsix.org/forum/viewtopic.php?t=56455 |
| Author: | spacecommander [ Mon Oct 27, 2014 4:47 pm ] |
| Post subject: | Z-bar sliding laterally when shifting Where to get bushings? |
I've got a 1982 Dodge W150 Powerwagon with the slant six 4 speed (with granny) tranny - anyway - my guess is the plastic bushings are shot as the z-bar linkage slides about 3/4 of an inch towards the bellhousing when shifting. Anybody got a good source for replacement parts like this? Really don't want to deal with the local dealer who views request like this as if asking for a radioactive strontium pellet for my spaceship. Oh, I see a spring clip shown in the exploded diagram but not sure if it's an external or internal part. If external - I don't see it. |
| Author: | DusterIdiot [ Mon Oct 27, 2014 5:49 pm ] |
| Post subject: | It's... |
This kit from Brewers...if it's sliding the bail wire is not holding the bushing in place. Also check to make sure your brackets/ballstuds are tight. http://www.brewersperformance.com/prodd ... p?prod=CSK |
| Author: | spacecommander [ Mon Oct 27, 2014 6:50 pm ] |
| Post subject: | Re: It's... |
Quote: This kit from Brewers...if it's sliding the bail wire is not holding the bushing in place. Also check to make sure your brackets/ballstuds are tight.
Hot dang! Thanks! I've been surfing the net with no luck so far. http://www.brewersperformance.com/prodd ... p?prod=CSK WOOHOO! Thanks again! |
| Author: | DusterIdiot [ Mon Oct 27, 2014 8:13 pm ] |
| Post subject: | Manual Transmission Stuff... |
There are really only two reliable places to get rebuild stuff for 4 speed stuff and linkage kits: Brewers Performance and Passon Performance FYI. |
| Author: | spacecommander [ Mon Oct 27, 2014 9:25 pm ] |
| Post subject: | Re: Manual Transmission Stuff... |
Quote: There are really only two reliable places to get rebuild stuff for 4 speed stuff and linkage kits:
Thanks, the first is already bookmarked from your last post . . . Brewers Performance and Passon Performance FYI. |
| Author: | nm9stheham [ Thu Oct 30, 2014 6:50 am ] |
| Post subject: | Re: Z-bar sliding laterally when shifting Where to get bushi |
Quote: Oh, I see a spring clip shown in the exploded diagram but not sure if it's an external or internal part. If external - I don't see it. If you are talking about the long zig-zag shaped wire clip along the length of the Z-bar, that is an external part. If you don't see it, you ain't got it!
| Author: | spacecommander [ Thu Oct 30, 2014 6:40 pm ] |
Quote: Quote: Oh, I see a spring clip shown in the exploded diagram but not sure if it's an external or internal part. If external - I don't see it. If you are talking about the long zig-zag shaped wire clip along the length of the Z-bar, that is an external part. If you don't see it, you ain't got it!Bet it holds the bushings to keep them from sliding, right? |
| Author: | Doctor Dodge [ Thu Oct 30, 2014 8:05 pm ] |
Yes... The wire clip passes thru 2 small holes in the z-bar and locks into a groove in the bushings. DD |
| Author: | spacecommander [ Sat Nov 01, 2014 9:19 pm ] |
Quote: Yes...
Thanks!
