| wondering which a bodys came with a dana rear 60 https://slantsix.org/forum/viewtopic.php?t=56496 |
| Author: | USAJon [ Sun Nov 02, 2014 5:29 pm ] |
| Post subject: | wondering which a bodys came with a dana rear 60 |
anyone know this. |
| Author: | Valleyant [ Sun Nov 02, 2014 9:14 pm ] |
Super Stock 426 Hemi 1968 Plymouth Barracuda and Dodge Dart |
| Author: | Exner Geek [ Mon Nov 03, 2014 6:33 am ] |
From 1966 on the Dana 60 was standard on stick 426 and many 440 B and E bodies, it might have also been an option with automatics on those cars. There was another little used Dana with a 9 1/4 ring gear for 440 stick C bodies. |
| Author: | slantzilla [ Mon Nov 03, 2014 8:34 am ] |
Quote: Super Stock 426 Hemi 1968 Plymouth Barracuda and Dodge Dart
Stick only, auto cars came with 8-3/4 rears. Danas were B body units, hence the odd cut wheel openings on Darts.So the correct answer is there was never was an A body width Dana 60 from Ma Mopar. |
| Author: | sandy in BC [ Mon Nov 03, 2014 1:38 pm ] |
There are a lot better ways to put power to the ground . They are pig heavy and no fun to work on. If you have a 5000 lb 2000hp pulling truck just maybe its better than a good 9" Ford.....but then you have the case that the truck weighs 5000lbs cuz you use stupid heavy stuff..... |
