It is currently Sat Jul 18, 2026 9:28 am
 Post subject: washer switch
PostPosted: Mon May 12, 2003 12:06 pm
going to put an after market external washer pump on. can i wire it into the wiper washer switch on the dash?i think i tried this once before on another car and it didn't work . does the washer work off of ground or pos?
thanx
73 swinger holley 5200, 2 1/4" exhaust .030 over new pistons , cam, .010 under crank. stock everything else. 1/4 mile about a week. 0-60 around 15 sec.
PostPosted: Mon May 19, 2003 12:26 am
Site Admin
I think the switch on the wiper connects to ground. Easy to test. First, use a voltmeter to see if there is voltage on the washer switch. If not, then use the ohms setting to see if the switch connects to ground when pushed (I suspect it does).
Chuck Rivers, Webmaster
Image Image Image Image
