Slant Six Forum https://slantsix.org/forum/ |
can someone id this engine and head? https://slantsix.org/forum/viewtopic.php?t=56514 |
Author: | USAJon [ Wed Nov 05, 2014 2:09 pm ] |
Post subject: | can someone id this engine and head? |
thought it was amid 1980's hydraulic but it has hourglass solid lifters http://smg.photobucket.com/user/jonwisper/library/slant |
Author: | wvenable [ Wed Nov 05, 2014 3:53 pm ] |
Post subject: | |
Just a quick glance at the head #'s would suggest 75 - 76. |
Author: | Reed [ Wed Nov 05, 2014 5:42 pm ] |
Post subject: | |
If that is the factory black paint on the head and block then they are both post-82 units. If someone has repainted them then the closest I can tell you from those photos they are post 75 (or whenever the peanut plug head came into use, I always for get the eact year). Have you checked the part numbers in the matrix? |
Author: | USAJon [ Fri Nov 07, 2014 5:43 pm ] |
Post subject: | |
look on the inet but no good luck as yet. |
Author: | DusterIdiot [ Fri Nov 07, 2014 6:03 pm ] |
Post subject: | Rlmao... |
funny...I put that head part number into the search on the board and got a post I added to help the engine/parts metrix... http://www.slantsix.org/forum/viewtopic ... ht=4027600 |
Author: | USAJon [ Sat Nov 08, 2014 7:09 am ] |
Post subject: | ok |
thanks dusteridiot the head came off the block, is that the same era stamped block 1975-1976 with a forged crank. trying down exactly what we have . |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
