| Pull The Windshield-simply For Cosmetic Reasons? https://slantsix.org/forum/viewtopic.php?t=56549 |
| Author: | suurthing [ Wed Nov 12, 2014 7:42 pm ] |
| Post subject: | Pull The Windshield-simply For Cosmetic Reasons? |
The upper dash area close to the windshield looks nasty from sitting so long (from moisture)...NOT from a leaky windshield--should i go the extra mile and have the windshield removed and that area repainted too-when i get my 68 dodge dart repainted? nobody thinks that i should...cause the windshield never leaked. i guess my real question is: What are my chances of my windshield leaking-after i remove it and re-install with a new gasket? |
| Author: | Dart270 [ Thu Nov 13, 2014 6:09 am ] |
The chances of your windshield leaking after reinstallation, even if you have a new gasket and windshield, are close to 100%. Bet on it leaking. So far, I have never had a windshield installed on any A-body (6-7 times, 64-74 cars) that did not leak. I made some headway by adding more silicone sealant after installation, but there was always a little leak even after that. Either nobody knows how to do it right these days, or the new gaskets are junk, or..... Good luck, Lou |
| Author: | ESP47 [ Fri Nov 21, 2014 10:29 am ] |
Probably close to 100% if you do it yourself and have never done one of these before. Closer to 50% if you get an old school windshield guy to do it. Make sure you use butyl sealant. The black stuff that doesn't dry and crack. |
