Hyper pak motor colors
https://slantsix.org/forum/viewtopic.php?t=56582
Page 1 of 1
Author:  ValiantBoyWonder [ Tue Nov 18, 2014 1:58 pm ]
Post subject:  Hyper pak motor colors
What color was the factory hyper pak motor that they put in that infamous valiant?
Author:  Valleyant [ Tue Nov 18, 2014 4:01 pm ]
I believe the first year and more 170's were Red. Try to find pics of the restored 1960 XNR for a really nice representation.
Author:  MichaelS [ Tue Nov 18, 2014 5:43 pm ]
I googled the XNR and noticed a couple things. The alternator is shifted to the middle, cool. And the dual exhaust uses flex pipe for the down tubes, interesting. Oh and it is red.
Author:  Danarchy [ Tue Nov 18, 2014 7:49 pm ]
I thought the Hyper-Packs were only Dealer installed, not from the factory???
Author:  Valleyant [ Tue Nov 18, 2014 10:52 pm ]
Correct....Dealer installed or you installed it yourself. Too bad color pics are not available, at least to my knowledge, but some early magazines that I have detail the hyper pack installation on a 1960 Valiant belonging to Briggs Cunningham.
Author:  MichaelS [ Thu Nov 20, 2014 4:42 pm ]
Did all hyper packs have the alternates moved inboard? I've seen a few others pictured on the net like that, what would be the benefit?
Author:  DusterIdiot [ Thu Nov 20, 2014 4:49 pm ]
Post subject:  It's...
Shorter fan belt, keeping the engine from throwing the belt at 6000+ rpm...it doesn't take much, a wobble in the alternator pulley would lunch your charging and cooling in one fraction of a second....been there and done that, will be relocating my alt on the next go through since my cars don' t have power steering.
Author:  wjajr [ Fri Nov 21, 2014 8:39 am ]
I too have derailed belts at the 6000 rpm range while in second gear; not a good thing to take place out on the open road to suddenly loose power steering, and get a boiling tea kettle in less than a quarter of a mile. This has happened several times to me during sea trials after a tuning session.
I did find that power steering pump was cocked off of square a wee bit which seamed to be the cause of belt problems.
I had to shim power steering bracket to get it true with crank pulley which took a bit of fiddling around to get it right. I suspect previous owner had welded PS bracket during Budweiser Engineering session...
Author:  hyper_pak [ Fri Nov 21, 2014 5:44 pm ]
Post subject:  Alternator
60 had the alternator on left. Moved soon afterward, not sure when. EARLY heads don't have the bolt boss to mount the alt bracket on the right.
