| The Cold Wave...ahem.. I mean MegaSquirt Tuing time https://slantsix.org/forum/viewtopic.php?t=56594 |
| Author: | Greg Ondayko [ Fri Nov 21, 2014 3:04 pm ] |
| Post subject: | The Cold Wave...ahem.. I mean MegaSquirt Tuing time |
The Cold snap hit early this year YAY... why you say? cause I can dial in the 20*-40* startup tables Cranking pulsewidth, Accel enrich. Afterstart Percentage / Time etc when it's this cold. I can only do it once or twice a day and with the col wave its been fun. This is also the first time I have really used tunerstudio for this stuff. Bought a Mini Laptop at the Pawnshop last year to replace the 20 year old thing that ran megatune. That got me to working on the advance and VE tables a bit - Some areas of my fuel map were too lean so I fattened em up a bit and no more bucking under heavy load ( > 60kPA Map) under 1000 rPM (stick car) I also did alot of other small fixes like spent a whole $5 and got a new PCV valve (the old one had a pentastar on it from 1979 and over 200,000 Miles) and a new valve cover breather, Also correctly set the Trigger offset with a timing light.. I had it Close(meaning It ran) for about 7 years.. Thought It would be time to check it with a light. I need to try to get the offset closer to 0* for rotor phasing sake. Really liking tuner studio so far! Happy EFI'ing! Greg |
