Slant Six Forum https://slantsix.org/forum/ |
Throttle return spring https://slantsix.org/forum/viewtopic.php?t=56602 |
Author: | Koa [ Sun Nov 23, 2014 12:41 pm ] |
Post subject: | Throttle return spring |
Author: | Reed [ Sun Nov 23, 2014 1:26 pm ] |
Post subject: | |
Most auto parts stores sell dual throttle return spring kits that can be bent to whatever length you need. Such as Napa Balkamp part number: BK 7354714 or NOE 7321005 |
Author: | spacecommander [ Sun Nov 23, 2014 4:07 pm ] |
Post subject: | |
What carbs did you install? 2 stock 1bbls or the Langdon 32DFT Carter/Weber pair? |
Author: | Koa [ Sun Nov 23, 2014 6:14 pm ] |
Post subject: | |
Thanks Reed. That's a good tip. I was just concerned that there was something I was overlooking. I installed a pair of matched Holley 1920s. They're just so danged easy to rebuild. I acquired a box of carbs that had lived under a retired mechanic's house for 20 plus years. There's a big Holley 4 barrel that should cover the cost of the lot . My arm still hurts from patting myself on the back. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
