| What Are The Symptoms of a Control Module Going Bad? https://slantsix.org/forum/viewtopic.php?t=56618 |
Page 1 of 3 |
| Author: | JCAllison [ Tue Nov 25, 2014 1:38 pm ] |
| Post subject: | What Are The Symptoms of a Control Module Going Bad? |
Hey all, Lorrie Van Haul, a 1967 Dodge Postal Van with a 225 Slant Six with the HEI Conversion has been doing just wonderfully for the past year. But last week, of a sudden she wouldn't start. All the connections to the HEI system was checked and everything seemed to be in order. Then just on a whim, the fuses to the Run Switch were pulled, and swapped around and the engine started right up, but there has what sounds like an intermittent, and quite random, muffled backfire, that has persisted since this not starting incident. The next day we were running errands, the backfire was still evident, and of a sudden the engine died. The first thing that was done was to spin the fuses, and she started right up again. Then this morning, figuring that the copper Fuse Holders on the fuse panel was corroded or oxidized, the Fuse Panel was removed and all the contact points were cleaned, and the fuses reinstalled using an anti-oxidant compound wherever contact was made. The Fuse Panel was then reinstalled, and checked to make sure that it was passing current. Each Fuse was passing 12.55 Volts. Turned on the Run Switch, activated the Start Switch, and all the engine would do was crank. There was absolutely no fire. Spinning the Fuses was to no avail. Have repeated checked the Run Switch, and it has always passed the tests, but am going to do it again tomorrow. The inability to start, plus the intermittent, and fairly frequent, random, muffled backfiring has led me to suspect that the LX301 Control Module MIGHT be the culprit in this situation. Am going to be taking out the Engine Cabinetry and Floor Board tomorrow in order to check the Spark Plugs, Distributor, and all the connections to and from the HEI conversion system. Lorrie has been performing marvelously since the last time I posted to the Slant Six Forum. She has, even on the coldest of mornings been starting with just the barest of touches of the Start Switch. She settles into a 650 RPM Idle instantly, and has up until this latest problem seemed to be glad to be alive. Still, would like to find out what the symtoms of a control module failing are. Any assistance would be appreciated. Hope this finds you all doing well. Thanks in advance. JC |
| Author: | WagonsRcool [ Thu Nov 27, 2014 6:28 pm ] |
Symptoms of a failing control module are: complete lack of spark- may only occur when hot or all the time. This type of electronic device will almost always works 100% or fails completely (subject to thermal conditions). I have never seen a "partial failure" mode where the module fires some of the time but misfires here or there. Now poor electrical connections can cause that, as could a marginal ignition coil, or a pickup coil problem, or lack of adequate voltage to the system. You can read my HEI trouble-shooting thread for more info. |
| Author: | wjajr [ Fri Nov 28, 2014 7:06 am ] |
For a period of time I ran hotter plugs in numbers one and six to help to keep those two cleaner and better firing at idle when I was jetted too rich; a Band-Aid fix I now realize. I got the idea from some article I think posted here in regards to racing; can't remember for sure. Since I have installed NGK plugs, have much better A/F mixture control, and cleaned up all things electrical in ignition circuits eliminating voltage drop. |
| Author: | JCAllison [ Fri Nov 28, 2014 12:01 pm ] |
Quote: For a period of time I ran hotter plugs in numbers one and six to help to keep those two cleaner and better firing at idle when I was jetted too rich; a Band-Aid fix I now realize.
Hey Mr. W,Lorrie is already running NGK ZFR5N Spark Plugs, and still the One and Six Plugs soot up. Maybe the Jets in the Bendix Stromberg Model W Carburetor need to be changed out for something a bit more lean. Quote: I got the idea from some article I think posted here in regards to racing; can't remember for sure.
The racers have all kinds of tricks that they use. One time read an article that told how to get the Spark Plugs all aligned so that all the little parts that are adjusted for gap are facing the same direction. It supposedly had some effect, but I couldn't for the life of me understand what it would be.Quote: Since I have installed NGK plugs, have much better A/F mixture control, and cleaned up all things electrical in ignition circuits eliminating voltage drop.
Lorrie's Fuse Panel got a thorough going over to remove corrosion/oxidization and the Fuses reinstalled using an anti-oxident compound.Last Wednesday Lorrie did really well not backfiring on the test drive after having adjusted the Reluctor Air Gap on the Mopar Electronic Distributor, but today we went to the grocery store and the backfiring is back. Am going to check the Reluctor Air Gap again tomorrow. It may need to be adjusted and then tightened down more than it got on Wednesday. Will just have to wait and see. What will be will be. Time will tell. Be well. JC |
| Author: | nm9stheham [ Fri Nov 28, 2014 5:07 pm ] |
Is the blackness on 1 and 6 a flat black or a shiny black? Flat black indicates rich; shiny (wet) black is oil. If rich, I gotta wonder if the spark plug resistance on 1 and 6 is getting a bit high and weakening the spark to those 2 cylinders. Those 2 wires will be longer and will naturally have higher resistance to begin with. Was the 12.55 volts measured while running or not? If running, that is NG; the charging system will be putting out around 14v +/- at the battery if properly functioning. |
| Author: | JCAllison [ Sat Nov 29, 2014 2:24 am ] |
Quote: Is the blackness on 1 and 6 a flat black or a shiny black? Flat black indicates rich; shiny (wet) black is oil.
Hey Mr. NM9,1 and 6 were flat black soot. Rubs off like a chalk mark. Lorrie doesn't have any smoke out of the Tail Pipe. She isn't burning any oil as the oil level is constant. Quote: If rich, I gotta wonder if the spark plug resistance on 1 and 6 is getting a bit high and weakening the spark to those 2 cylinders.
That might be.Quote: Those 2 wires will be longer and will naturally have higher resistance to begin with.
Am running MSD 8.55 mm Spark Plug Wires and the set is less than three years old. The wires are touted to have a very low resistance. What WAS noticed was that both the 1 and 6 Plugs had gaps of over 0.050 when they were pulled last Wednesday. All the other plugs were between 0.040 and 0.045.After reading Daniel's HEI Sticky and WagonsRCool's essay, the point made about the NAPA MO-3000 Rotor stood out. Lorrie Doesn't have the long tipped Rotor. It is Black and has a short tip, and it seemed to me that it was a bit burnt on the tip. Quote: Was the 12.55 volts measured while running or not?
That was with it not running, and after having cranked on the Starter for about three 15 second times. Normally, the battery checks out to be 12.6+ before doing anything.Quote: If running, that is NG; the charging system will be putting out around 14v +/- at the battery if properly functioning.
Normally, the Alternator is putting out just under 15 Volts with the Engine running.Took Lorrie out to the the grocery store yesterday and the backfiring was the worst it has ever been. Am going to be removing the Engine Cabinetry this morning and checking, in this order: 1. The Battery Voltage; 2. The Voltage to the B Terminal of the LX-301 Control Module which will have gone through the Run Switch. 3. The Reluctor Air Gap. It was set to 0.010 last Wednesday, and the Retaining Screw was tightened, but may NOT have been tight enough. It was done with just a screwdriver. If the Reluctor Air Gap is not 0.010, will reset it and tighten the screw with a screwdriver blade in a ratchet to make sure it is tight enough. 4. Clean up the Tip of the Rotor. 5. Check the Distributor Cap for Carbon Trails. 6. I'm "nearly' positive that there is a NEW set of NGK ZFR5N Spark Plugs here, but they've been put somewhere where I wouldn't forget where they are, and I can't remember where that is! If they can be found, will swap the old one out for new ones gapped to 0.045. Called NAPA yesterday to order a NEW MO-3000 Rotor, a set of NGK ZFR5N Spark Plugs, and a Standard Bluestreak CH-401X Distributor Cap, but apparently they weren't open because of the holiday weekend because no one answered the phone. Am thinking that today, if the NEW ZFR5Ns can't be found that I will swap the 1 and 6 Spark Plugs to the 3 and 4 Cylinders, and put the Plugs from 3 and 4 into the 1 and 6 cylinders to see what a test drive will do to them. Also, yesterday, after driving to the grocery store, when I came out there was the odor of gasoline in the truck. Checked the Bendix Stromberg Model W Carburetor, but there weren't any leaks anywhere, but had to put the Accelerator Pedal to the floor and crank for about ten seconds before Lorrie started. So there is something strange going on there. Usually Lorrie starts with just the barest of touches to the Start Switch. Even in the morning when it's cold. So, have a full day planned for today. Will let you know how it goes. Thanks for the response. Hope you are well. JC |
| Author: | 65CrewCabPW [ Sat Nov 29, 2014 2:20 pm ] |
Quote: Symptoms of a failing control module are: complete lack of spark- may only occur when hot or all the time. This type of electronic device will almost always works 100% or fails completely (subject to thermal conditions). I have never seen a "partial failure" mode where the module fires some of the time but misfires here or there. Now poor electrical connections can cause that, as could a marginal ignition coil, or a pickup coil problem, or lack of adequate voltage to the system. You can read my HEI trouble-shooting thread for more info.
I have actually seen precisely this behavior before in a failing module.I have also seen the wires breaking to the dist pickup and caused similar shenanigans. |
| Author: | JCAllison [ Sun Nov 30, 2014 12:53 pm ] |
Quote: I have actually seen precisely this behavior before in a failing module.
Hey Mr. 65CCPW,I'm not sure of what behavior you are referencing. Is it what Mr. WRC said that you have seen, or what I have described? Quote: I have also seen the wires breaking to the dist pickup and caused similar shenanigans.
Have checked all the Wires in Lorrie's HEI System, and they all check out perfectly. Have suspicions about what is going on, but won't know for sure until next Thursday. Will update the thread then. Anyway, thanks for taking the time and making the effort to respond. It is much appreciated. Be well. JC |
| Author: | JCAllison [ Thu Dec 04, 2014 4:15 am ] |
Hey All, Ordered a NEW NAPA Eichlin MO-3000 Rotor. It was delivered last evening. It is tan colored plastic and has the 0.060 extended tip. Included in the delivery was a set of six NEW NGK ZFR5N Spark Plugs. Removed the Distributor Cap, and Spark Plug Wires yesterday and tested each circuit from the Distributor Cap Contact Points to the Spark Plug Contact Points. The MultiTester was set on "AUTO", and the reading of each Spark Plug Wire/Distributor Cap Contact Point was between 3.7 to 5.7 ohms (am assuming that is K-Ohms, but am not sure). Could get no reading on the Ignition Coil Wire, and assumed that the MultiTester Probe was not making contact with the Center Contact Point in the Distributor Cap. Used the RotoTool with a small Grinding Stone in an attempt to clean the Distributor Cap's Center Contact, only to find that it is NOT metal, but is Carbon. Was worried that I had REALLY messed up the Distributor Cap, but upon reinstalling everything, Lorrie started right up. Still, I may have screwed up the Distributor Cap's Center Contact Point. Will just have to wait and see. Am going to check to see if the NEW MO-3000 extended tip Rotor is going to make contact with the Distributor Cap Contact Points, and if it will clear, will install it and take Lorrie for a test drive. If the backfiring is abated, will button everything up and figure that Lorrie is good to go. If it doesn't solve the backfiring problem, am going to install NEW NGK ZFR5N Plugs in Cylinders One and Six. The reason for installing only Numbers One and Six is that last Saturday, the Contact Points in the Distributor (which, BTW are either Brass or Copper) were cleaned. Then yesterday when the Distributor and Spark Plug Wires were removed for testing, it was noticed that ALL the Distributor Contact Points except the Number One Contact Point had slight "burn" marks on them. And the Number Six was the slightest of all. It looked as if Numbers One and Six hadn't been firing as had the others. Also, tried to order a Standard Bluestreak CH-410X Distributor Cap from NAPA, only to be told that CH-410X is not a "good" parts number. Have subsequently read all the threads here at the SSF concerning the problems with getting the Standard Bluestreak CH-410X Distributor Cap, bt didn't find any definitive reference to what Distributor Cap to get, considering the CH-410X's unavailability. The Distributor Cap presently in Lorrie is a heavy duty grey colored unit with either Brass or Copper Contacts. If I have screwed up the Center Contact Point by hitting it with a grinding wheel in the RotoTool, and it needs to be replaced, what should I look for? Will keep you all updated on whatever progress is made. Take care. JC |
| Author: | JCAllison [ Thu Dec 04, 2014 7:25 am ] |
Hey All, Installed the NEW NAPA Eichlin MO-3000 extended tip Rotor, took Lorrie for a test drive, and not a single backfire! Am going to reinstall her Floorboard and Engine Cabinetry and declare her backfiring problem solved. Want to thank everyone for their assistance. Hope this finds you all doing well. JC |
| Author: | Danarchy [ Thu Dec 04, 2014 9:27 am ] |
Standard Bluestreak CH-410X Distributor Caps are available on eBay, I just bought a couple.($12 each + postage) |
| Author: | JCAllison [ Thu Dec 04, 2014 12:18 pm ] |
Quote: Standard Bluestreak CH-410X Distributor Caps are available on eBay, I just bought a couple.($12 each + postage)
Hey Mr. D,Would you possibly have the URL? Thanks. JC |
| Author: | Danarchy [ Thu Dec 04, 2014 12:35 pm ] |
http://www.ebay.com/itm/Distributor-Cap ... db&vxp=mtr |
| Page 1 of 3 | All times are UTC-07:00 |
