Slant Six Forum https://slantsix.org/forum/ |
Bronze Lined Bearings? https://slantsix.org/forum/viewtopic.php?t=56620 |
Author: | nm9stheham [ Tue Nov 25, 2014 6:36 pm ] |
Post subject: | Bronze Lined Bearings? |
Been working engines for a few decades and never ran across this: Mopar bronze surfaced rod bearings...... What purpose are these for, and what do they do that is special or different ? |
Author: | Charrlie_S [ Wed Nov 26, 2014 5:24 am ] |
Post subject: | |
Never heard of them, either. Can you show a link or something? Where did you hear about them. |
Author: | DusterIdiot [ Wed Nov 26, 2014 6:29 am ] |
Post subject: | Yep... |
Quote: What purpose are these for, and what do they do that is special or different ?
Bronze is used in applications where wear resistance is highly desired being it's a slightly harder material than the tin/copper babbitt. Typically these are seen in industrial applications or constant run high rpm applications, never hear of them being used in auto applications.
Author: | nm9stheham [ Wed Nov 26, 2014 6:35 am ] |
Post subject: | |
OK that is making some sense. since the /6 was used in some industrial apps. A couple of NOS /6 bronze surfaced rod bearing sets showed up on fleaBay, which is what caused me to ask: http://www.ebay.com/itm/370627279459?_t ... EBIDX%3AIT |
Author: | SlantSteve [ Wed Nov 26, 2014 12:25 pm ] |
Post subject: | |
The E49 Valiant Charger 265 triple Weber engines had them from the factory in Australia. Pretty sure the Ford inline six had them in early 4 main bearing models .... I saw a main bearing set for on that was bronze,not sure if it was OEM. Nothing special about them,lots of better choices out there these days. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
