It is currently Fri Jan 31, 2025 4:54 am
 Post subject: Water pump impellers
PostPosted: Sun Nov 23, 2014 11:23 am
Hi there all,I have a choice of two water pumps to fit to a street driven cruiser type slant ...one is the OEM style pump and it has the original design impeller with a disk face,six blades and six holes about 5/16" drilled in the disk face. The other pump is the newer style open type impeller with six sheetmetal blades,open with no disk on the end. I'm sure both do the job just fine ,just tossing up which to fit.....any ideas? Thanks!
PostPosted: Mon Dec 08, 2014 6:37 pm
The closed impeller OEM design is more efficient and less prone to cavitation.
Mitch
Users browsing this forum: Bing [Bot], Semrush [Bot] and 6 guests
