| GM HEI conversion - what to do with ballast resistor-solved! https://slantsix.org/forum/viewtopic.php?t=56670 |
| Author: | sargentrs [ Fri Dec 05, 2014 11:05 am ] |
| Post subject: | Figured it out |
Tried various things but this worked. Make a jumper wire with 1 male spade on one end and a double (or 2 wire) male spade on the other end. Use this jumper wire and connect the top 2 terminal ends (disconnected from the resistor) together. Use the 3rd spade as your "trigger" source for the HEI relay. Disconnect and let hang, or fasten out of the way, the bottom 2 resistor terminal ends. Thanks to all! |
