| compression ratio https://slantsix.org/forum/viewtopic.php?t=5669 |
| Author: | Guest [ Mon May 05, 2003 8:51 pm ] |
| Post subject: | compression ratio |
I need some help here. I have a head milled .080, motor bored out .060 useing a stock head gasket can anyone tell me the compression ratio. Compcams has a cam I am thinking of useing but the catalog says it is designed for ratios of 9.1 or less. Also has anyone ever used a marine cam? A buddy of mine made that suggestion, he used to race circle track and said that the cam he used. thanks for the help. OD |
| Author: | Doctor Dodge [ Mon May 05, 2003 9:54 pm ] |
If you "cc" the head and measure how far down in the hole the pistion is, we can figure the static CR. Without those measurments anything stated would be a "WAG". (my wild-a$$ guess is 8.8, do we hear 9...???) DD |
| Author: | Super6 [ Sat May 10, 2003 7:55 pm ] |
My "WAG" would be around 9.4-9.5 -S/6 |
| Author: | Eric W [ Sat May 10, 2003 9:09 pm ] |
The mairine cam was used as the standard cam from '71 to '77 in all slant six's. |
