5 V gauge upgrade puts out 7V
https://slantsix.org/forum/viewtopic.php?t=56744
Page 1 of 1
Author:  drtwgn [ Thu Dec 18, 2014 3:23 pm ]
Post subject:  5 V gauge upgrade puts out 7V
Greetings. I built the transistor/capacitor/heatsink 5V output for my gauges. I hooked the assy. across a 12 V battery to test the output, and it was 7.0 V. I double-checked the transistor number, and it is correct (not to say the transistor is truly correct). I know the transistor got hot while soldering, but I'm pretty good at soldering, and it did not get hot too long. Questions:
Could the heat of soldering increased the V output 2.0 degrees? Kinda doubt it.
If I test the assy. by putting full car battery 12V through it briefly, would that destroy the components? A 7.0 V reading suggests the transistor is not destroyed by such a test.
I've built another assy, using the same transistor part no. 7805. I think the cap is only 10 uf. What would be a better way to check the assy's. output?
Could I run the gauges on 7V, or would they read falsley hi or low?
Super close to getting this 8 year project back on the road, so please help if you can. Thanks!!!!!!!!!!!!!!!
Author:  nm9stheham [ Fri Dec 19, 2014 4:17 pm ]
No, the heat should not increase the output by 2v. Melting the silicon or the internal bonding wires would pretty much be guranteed to have a much more damaging effect.
Double check your connections to the 7805 to make sure you don't have 2 of the leads reversed; I suspect that is the case. Do you have a diagram depicting the pins out of the 7805 package?
And, are you measuring the output voltage from ground to output? You could get 7 volts if you had your voltmeter connected between input and output.....
I am not sure what you mean by 'putting 12 volts through it'. The 12v goes from IN to Ground (pins 1 and 2) and the output is from OUT (pin 3) and is referenced to Ground (pin 2).
By the way, this is not just a transistor, it is a single packaged integrated circuit. This ought to produce a very stable 5V even down to no load current.
Author:  drtwgn [ Sun Dec 21, 2014 5:16 pm ]
You were right on, nm9stheham.
I was measuring between the input and output pins. Made sense to me to measure between those, but I'm ignorant of what's inside that black little box. Measuring between pin 3 and ground gave a nice, 5.00V.
"Putting 12 V through it" should have said, "Applying 12 V to it."
A little more excitement to motivate me towards the goal line. THanks
for taking the time to help!!!!
Author:  nm9stheham [ Mon Dec 22, 2014 8:09 am ]
Cool ! It's always good to find the 'problem' AND the reason!
